Siglent SSG Series Signal Generator Instrument Driver Readme
To rate this driver, go to the driver download page on the Instrument Driver Network.
1. Overview
Instrument Driver Technology:  LabVIEW Plug and Play (project-style)
Manufacturer: Siglent Technologies
Supported Language(s):  LabVIEW
Supported Model(s):  SSG3032X, SSG3032X-IQE, SSG3021X, SSG3021X-IQE, SSG5060X, SSG5060X-V, SSG5040X, SSG5040X-V
Model(s) Tested:  SSG3032X-IQE, SSG5060X-V
Interface(s):  USB, GPIB, Ethernet
Firmware Revision(s) Tested: 1.0.3.1.19R2, V1.1.1.2.1
Certified:  No
NI Supported:  No
Source Code Available:  Yes
Driver Revision:  2.0
Original Release Date: 05/2019
Current Revision Date: 09/2020
2. Required Software
Some software components need to be installed before using this instrument driver. The minimum versions of these components are listed below, and can be downloaded from the Download Site.
VISA 5.0 or later
Refer to the LabVIEW Help for more information about software requirements. You access the LabVIEW Help by selecting Help»Search the LabVIEW Help.
3. Known Issues
To report issues or provide feedback about this instrument driver, please send an email to instrument.drivers@ni.com.
4. Revision History
The latest version of this and other LabVIEW and LabWindows/CVI instrument drivers can be downloaded at the
Initial release, REV 1.0, 05/2019
Created by: Peter.Chen, Software Development Department, SIGLENT TECHNOLOGIES CO., LTD
REV 2.0, 09/2020
Modified by: Peter.Chen Software Development Department, SIGLENT TECHNOLOGIES CO., LTD
(1) Update icons for all VIs.
(2)Add support for SSG5060X, SSG5060X-V, SSG5040X, SSG5040X-V
New VIs:
Config ARB State.vi
Config BaseBand Offset.vi
Config Marker Setting.vi
Config Marker Utilities.vi
Config Modulation Atten.vi
Config Modulation Filter.vi
Config Multi Carrier Table.vi
Config Multi Carrier.vi
Config Real Time AWGN.vi
Config Sample Clock.vi
Config Select Waveform.vi
Config Trigger.vi
Config Waveform Header.vi
Config Waveform Segment.vi
Config Waveform Sequence.vi
Config Waveform Utilities.vi
Config AWGN.vi
    Config Custom State.vi
Config Data Source.vi
Config Filter.vi
Config Modulation.vi
Config Save Waveform.vi
Config Compensation Channel.vi
Config IQ Adjustment.vi
Config IQ Mod State.vi
Config IQ Output.vi
Config IQ Source.vi
Config IQ Swap.vi
Config Multitone.vi
Configure Save and Load.vi
