SSG5000X4 and 6 GHz models
Released May 2020
Pricing from $ 8809
https://int.siglent.com/products-overview/ssg5000x/https://siglentna.com/rf-generators/ssg5000x-series/Main Features
Frequency up to 4 GHz / 6 GHz
0.001 Hz frequency setting resolution
Maximum output power up to +26 dBm (typ.)
Phase Noise: -120 dBc/ Hz @ 1 GHz, 20 kHz offset (typ.)
Standard AM & FM & PM & Pulse modulation
Pulse train Generator (option)
External IQ signal Generator (option)
High accuracy clock source (option)
SSG3000X3.2 and 2.1 GHz models
https://www.siglentamerica.com/rf-generators/ssg3000x/https://www.siglenteu.com/rf-generators/ssg3000x-series-of-signal-generators/![](https://www.eevblog.com/forum/testgear/siglent-ssg3000x-series-rf-signal-generators/?action=dlattach;attach=515936)
SSG3000X series RF signal source, output frequency range from 9 KHz to 3.2 GHz, standard AM & FM & PM analog modulation, pulse modulation, pulse sequencer, power meter control kit, etc., equipped with baseband source (eg: SDG 6000X), Implement IQ modulation for R&D, education, production, maintenance and other related fields.
Features
● Maximum frequency 2.1GHz/3.2 GHz
● Output frequency resolution up to 0.01Hz
● Output power range from +13dBm to -110dBm
● Phase noise <-110 dBc/Hz@1 GHz, offset 20 kHz (typical)
● Amplitude accuracy ≤ 0.7dB (typical)
● Support AM/FM/PM analog modulation, support internal and external modulation
● Pulse modulation function, the on-off ratio can reach 70dBc
● Pulse train generator, user-definable pulse sequence (optional)
● Supports external IQ modulation and outputs IQ modulated signals (optional)
● Power meter control kit for easy power meter measurement and control power output
● Support web remote control, which is convenient for users to remotely control devices
● 5-inch capacitive touch screen for user-friendly operation
● Rich communication interface: USB-HOST, USB DEVICE (USB-TMC), LAN (VXI-11, Socket, Telnet), optional GPIB
Datasheet:
https://www.siglentamerica.com/download/7543/US Pricing:
SSG3021X 9 kHz~2.1 GHz $2549
SSG3032X 9 kHz~3.2 GHz $4009
SSG5000X video:
https://www.youtube.com/watch?time_continue=2&v=LObh3AZTTGM&feature=emb_logo The Signal Path review video SSG5060X-V
