Hi!
So I recently have gone the extra mile and bought myself a worthy soldering iron!
But a worthy soldering iron needs also a worthy tip!
I got myself some tips but they are better for heavy stuff, I expected something smaller, could not judge from the datasheet correctly.
So what would you use for SMD work, rework? I usually don´t go under 0402 in packages and 0.4mm pitch and I have bigger tips to handle bigger stuff.
I looking for something in the "Louis Rossmann" micro-pencil category, but I could be wrong so I would like some suggestions before I go out and spend 100€ on tips :-P
Thanks!
