I've asked for more file types for a little while, SSA3kX is the first of any Siglent AFAIK to offer jpeg and we hope there will be more in the future. Png? Maybe. Discussion with Tech support has been around the time to convert each of the different types and the effect it has on the Save file computation times.
Jpeg takes a few more seconds to compute than BMP and with the jpeg format I have missed files by removing a USB pen drive too quickly before it has fully loaded. Annoying, yes but with the SSA3kX it is very quick to use the File management UI to check the file is present and does actually contain data.
I need to learn to more patient.
It can nearly say that jpeg in this kind of use is mistake. It is widely known. It is very ok for photograph but not at all ok for technical graphics. PNG is widely known and supported. Of course fully lossless packaging is best but if use example GIF (one of most widely supported format and old also) then need change SSA colors to match 256 colors (what is not at all problem, only it need do)
When designer put jpg to this kind of purpose in equipment it can nearly say it is design error.
PNG is perhaps best possble what support also wide color pallette but for technical purposes GIF is even more better because it is true lossless. Still it produce small file size. But, color pallette is reduced and if we convert higher color depth image to GIF there may come very fun results, so it is best if original is also 256 colors. In teccnical equipment display like Spectrum analyzer imho 256 color depth is not at all problem.
Please Siglent:
Give us freedom to select whole display color map by user. I do not like these "childrens toy" colors.
This is just one table in UI.
Take example old ancient R&S Spectrum and look how they have done it (at this time display was color crt). So simple, so very simple.
User select example one trace, After then he turn knob and trace color change. After user find ok color he leave it and go to other things for adjust. 2 minutes and you have adjusted whole display just as you want, simple. Next time you turn it on it remember it. Only if do deep reset (not preset) set it back to factory state. Or something like it.
Only way to do it is fully freedom to user. Manufacturer made "skins" are not ok, mostly they are just terrible.
All peoples color taste is not same, also culture may affect this. Then, peoples eyes are different. Some times it is nice to "harmonize" all equipments so that when I look long time red display and then I move my eyes to blue display it is just - terrible. (it may some times take long time before eye adapt and "negative" color disappear.
Then some times we need work dark. How hell these equipments can use in dark, example in observatory. Only way is buy lot of color and gray filters, or do hardware modifications.
Please Siglent:
If you really want keep JPEG there it is ok, no need delete but please give us least PNG. (GIF only if also native color depth is reduced to 256)
