The worry is; how many other accessories will I need as well?
Decent cables with BNC and SMA quality connectors; high quality RG58 C/U as a bare minimum, RG223 or RG400 are much preferable. You need a really good shielding in order to make use of the dynamic range of a decent SA.
Bunch of adaptors SMA/BNC, BNC/N ...
DC block to protect the SA input
Couple of fixed attenuators, a set of 3/6/10/20dB will be handy, but is hard to obtain with BNC for bandwidths >1GHz, so you'll probably have to go for SMA, hence you need the adaptors...
Couple of 50 ohm dummy loads for BNC/SMA
Wideband power splitter/combiner
Optional: Directional coupler
And most importantly: two decent RF signal generators.
At least one of them should provide good phase noise performance.
The 2nd generator together with the power combiner is needed for IM tests in order to determine the 2nd/3rd order dynamic ranges...
You certainly won't need a waveguide for frequencies up to 2GHz...
