Hello, it looks like by joining several information throughout the board I was able to transition from a SSA3000X-Plus to a SVA1000X device...: a big thanks to TV84 and all the guys in the forum who contributed to gather all the info to help people achieve this goal.
Having said that, I have a question :
Before approaching the step where everybody must copy the calibration data into the SSA/VNA, most probably just before crossflashing the firmware with the patched one ( TV84's speed method ), I took a look at
/usr/bin/siglent/firmdata0/cali/ and noticed that the two files, with the same size of the soon-to-be-copied, were already there.
Hence, I did not copied the calibration files inside the device, I just thought that maybe, since my unit is rather new, Siglent at a certain point started to create and copy those files already inside the device, to shorten the process or getting ready to sell the VNA as an option with a license code.
Am I missing something....? Should I get back and copy those files ? All in all I read somewhere that they are for the initial setup of the VNA, and once you calibrate manually OSL, they are not used anymore in the session
Any idea ?
Tnx
Andrea
