Author Topic: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers  (Read 722964 times)
Offline Mick B
Re: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers
« Reply #2275 on: May 10, 2023, 06:18:45 pm »
Hello, I am having a hard time telnetting into my fully working SSA/...SVA1032+. FW 3.2.2.5.1R1  It was working fine. Now the only way to get in is to use DEBTTT in SCPI then I can telnet 192.168.0.000 and then put in name and ding1234. Using SVA1000_telnet_11410.zip holds the door open but won't let me in. Looking at the /usr/bin/siglent/startup_app.sh File I see this /usr/bin/siglent/config_eth0.sh
sleep 1
portmap &
/sbin/telnetd -l /bin/sh -p 10101 &
/usr/bin/siglent/Aladdin &
echo "startup_app.sh   end++++++++++"
telnetd&
- /usr/bin/siglent/startup_app.sh 71/71 100%
I don't think the "telnetd&" line is suppose to be there, I have edited it out but it just comes back.
 Any ideas? Or should I just be glad I can get into it at all?
Online tv84
  • Country: pt
« Reply #2276 on: May 11, 2023, 07:42:34 am »
Are you telnetting to port 10101? If so, you don't need credentials.
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #2277 on: May 11, 2023, 08:55:06 am »
If you have everything working as you want it and can activate telnet by issuing a simple SCPI command, I would recommend to not mess any further with  your device!
If you want to be able to mess around a telnet console, get a Raspberry Pi! Your SSA/SVA is a test equipment - use it with care.
Offline killingtime
« Reply #2278 on: May 12, 2023, 12:10:29 pm »
Hi, does anyone know what Lupusz is on about in the post below?
https://www.eevblog.com/forum/testgear/siglent-ssa3000x-spectrum-analyzers/msg3470576/?topicseen#msg3470576
From what I can gather, he's saying if you want to make S11 SWR reflection measurements on a SSA3000x Plus (non-SVA), you don't need an external reflection bridge (?), because you can use the internal one, by terminating the TG output with 50 ohms.
I thought all SSA models did need an external bridge?
Offline EE4all
« Reply #2279 on: May 12, 2023, 12:56:51 pm »
 After "upgrading" to an SVA, my NSP_trends_config_info.xml  looks like below. Should I remove the second product ID, and rename the first one to SVA1032X, or keep two entries there and only update one? Does it matter?
Also, should I change the PID from 0x1305 to 0x1301 as indicated in an earlier post, or not? Does it matter?
<?xml version="1.0" encoding="UTF-8"?>
<nsp_trends_info_root>
   <device>
      <language>english</language>
      <pid>0x1305</pid>
      <vid>0xf4ec</vid>
      <product_type_1>SSA3032X Plus</product_type_1>
      <product_type_2>SSA3021X Plus</product_type_2>
      <manufacturer>Siglent</manufacturer>
      <Support_Touch_Flag>1</Support_Touch_Flag>
      <Support_VXI11_Flag>1</Support_VXI11_Flag>
      <file_prefix>CP_</file_prefix>
   </device>
</nsp_trends_info_root>
Offline tautech
« Reply #2280 on: May 12, 2023, 08:59:50 pm »
They do....
While SSA3kXP and SVA essentially share the same HW they have different modes of operation where the internal bridge is only used in VNA mode which can't be selected in SSA models that require a RLB for DUT isolation and with them a S11 measurement is not possible in Analyser mode.
Lupusz is correct as he is using the instrument in VNA mode.
The following users thanked this post: killingtime
Offline Mick B
« Reply #2281 on: May 13, 2023, 08:41:05 pm »
Hello tv84, A personal Thank you! There are lots of contributors (Thanking you to!) on this bus, but you appear to be the mechanic and driver.
Yes telnet 10101 192.168.2.000   The response telnet: could not resolve 10101/192.168.2.000: Servname not supported for ai_socktype
The same thing happens when using your  SVA1000_telnet_11410.ADS file.
thanks again.
Offline Mick B
« Reply #2282 on: May 13, 2023, 09:02:35 pm »
I was just showing someone how telnet worked did not have anything else to use that's when I found it didn't work. I wasn't planning to screw with it.
While your here, can you tell me, am I missing any features that are not enabled that work on this unit?
Offline tautech
« Reply #2283 on: May 13, 2023, 09:10:36 pm »
In earliest units TG and VNA were options but in later SVA units they were both added and SVA prices increased to cover particularly the VNA option.
Use the US webpage option selection to see what is missing although it appears you have them all.
https://siglentna.com/spectrum-analyzers/sva1000x-spectrum-vector-analyzer/
The following users thanked this post: Mick B
Online tv84
  • Country: pt
« Reply #2284 on: May 13, 2023, 09:12:12 pm »
192.168.2.000
This is an invalid IP. You'll never get it to work with such config. If you are not comfortable with IP addressing, configure DHCP on the machine and let it grab an IP from your router.
Offline DeDe
« Reply #2285 on: May 13, 2023, 09:13:32 pm »
telnet needs first hostname/IP and then port number:
telnet 192.168.2.000 10101
And of course .000 ist an invalid IP..
Offline EE4all
« Reply #2286 on: May 13, 2023, 11:31:27 pm »
   <device>
      <pid>0x1305</pid>
      <vid>0xf4ec</vid>
   </device>
Anyone?
Offline Mick B
« Reply #2287 on: May 15, 2023, 02:12:44 am »
192.168.2.000
My bad, just a habit of never putting information out on the web, silly I know this information is already out there. DeDe. found the problem. I had it backwards port number then the IP address (a senior moment) Thanks
Offline Mick B
« Reply #2288 on: May 15, 2023, 02:19:13 am »
Thank you, yes that was the problem. I don't use the command line much anymore. I used to, starter out with EDLIN & Basic but that was a lifetime ago. WINDOWS |O
Offline killingtime
« Reply #2289 on: May 22, 2023, 09:49:32 am »
Has anyone got a block diagram of the major internal components for a SSA3000X+?
I've looked though the user manual, service manual and application notes from Siglent and can't find one. It would be nice to know where they've actually put components like the attenuator, pre-amplifier and different mixers so I don't have to guess. They might have done something new, who knows.
An image search on Google does bring back many diagrams, but all generic. Best one I've found so far is attached.
Thanks.
Online tv84
  • Country: pt
« Reply #2290 on: May 24, 2023, 08:55:39 pm »
Don't reinvent the wheel. Just overwrite your .xml with the attached file, taken from an "official" SVA1032X.
The following users thanked this post: EE4all
Offline DL4JY
« Reply #2291 on: June 09, 2023, 07:44:11 am »
Hi ,
Siglent released new firmware for the SSA3000x (plus & R) & SVA1000x : V3.2.2.6.0R7
New Functionality:
• Add ECal in VNA mode
• Add three new formats in VNA mode: Unwrap Phase/Real/Imaginary
• Add Z Reflection in VNA mode
• Add PM demodulation in MA mode
• The time of analog demodulation in MA mode is adjustable
Now the question - has somebody already been so brave to test? I am interested in the results for an upgraded SSAx+ to SVA.:-)
Any advers effects ??
Haven't seen an updated Manual so far, are there descriptions of the added functionality other than from e.g. Keysight et. al.?
Hasta la vista
« Last Edit: June 09, 2023, 08:01:22 am by DL4JY »
The following users thanked this post: tautech, james38, tubularnut, bicycleguy, dibro
Offline tomud
« Reply #2292 on: June 09, 2023, 02:10:45 pm »
Hi ,
Thanks for the information :) The firmware upgrade went through without any problems...
For every complex problem, there is a solution that is simple neat and wrong...
The following users thanked this post: DL4JY
Offline EE4all
« Reply #2293 on: June 09, 2023, 10:01:50 pm »
Yes, the firmware update went just fine with my SVA that was earlier "upgraded" from a SSA.
Offline RoV
« Reply #2294 on: June 12, 2023, 08:07:00 am »
Confirm that the SVA1032X 3.2.2.6.0R7 upgrade works, but...
 |O  >:(
still 10 kHz BW only (grayed) in VNA mode!
I should really buy a new NanoVNA to overcome this problem
Offline Marcel G
« Reply #2295 on: June 12, 2023, 10:30:51 am »
Here it also succeeded with the new firmware (updated SSA to SVA).
I think you expect too much the Spectrum Analyzer is pretty good for the money but the VNA function is just a toy.
Once you have worked with a real VNA you will not want anything else and you will soon forget the VNA function in the Siglent.
« Last Edit: June 12, 2023, 10:35:56 am by Marcel G »
Offline RoV
« Reply #2296 on: June 12, 2023, 01:20:38 pm »
I don't agree with you. It is a T/R unit and not a full 2-port and this is a big limitation, but even hp used to build T/R units (e.g. 8714ET). Apart from this, it works quite well and the main limitation, in my opinion, is the IF bandwidth: 10 kHz is terrible. And it is clearly a software limitation, because the RF hardware is quite stable in frequency and has a phase noise low enough to reduce the IF bandwidth perhaps to 10 Hz. That would greatly improve the dynamic range.
Offline tomud
« Reply #2297 on: June 12, 2023, 02:13:57 pm »
 |O  >:(
Hmm, did someone say that they will add a change in bandwidth in VNA mode in the new firmware ? Alternatively, has anyone sent a proposal for such changes in the firmware to Siglent ?
However, another question, does anyone know what ECal models support SVA and whether it actually works ?
I personally think about the SNA5000 - only this price  :scared:
...and here it already shows SNA6000  :popcorn:
https://www.siglent.com/u_file/download/22_12_12/SNA6000A_DataSheet_DS09060_C01B.pdf
« Last Edit: June 12, 2023, 06:43:25 pm by tomud »
Offline RoV
« Reply #2298 on: June 12, 2023, 02:50:29 pm »
I think the issue is very clear to Siglent, otherwise there wouldn't be an "IF bandwidth" option in the GUI... that, unfortunately, is grayed at 10 kHz, as it was more or less since the beginning.
The issue was discussed several times in eevblog and the option is long waited, I think they read the forum. I don't know of direct contacts to signal the issue, perhaps tautech could do so.
Offline tomud
« Reply #2299 on: June 12, 2023, 06:20:32 pm »
Yes, I know that this option is currently inactive and something actually reminds me that the subject of the BW in the VNA mode was discussed. However, this does not mean anything and so the currently inactive option in one of the firmwares may well be removed.
Tautech mentioned that people from Siglent read this forum, but in such a long thread (there's also a thread about SVA https://www.eevblog.com/forum/testgear/siglent-sva1015x-1-5ghz-spectrum-vector-network-analyzer-(coming)/ ) it's very easy to miss something (even for someone who follows these topics often). Maybe it would be easier if there was a topic like in the case of oscilloscopes (bugs in the firmware and proposals for new functions).
IMHO, I still say that without submitting such proposals by distributors and customers themselves to support, it is difficult to count that writing only on the forum will somehow affect the manufacturer. Let's say as if they had to closely follow all the topics on all forums in the world, they would not have employees to read all of it  :-//
Siglent for the SVA1000X and SHA800A models (higher dynamics 90dB vs 114dB, most likely improved electronics compared to the SVA1000X) clearly states IF BW 10KHz - so it is not known if they plan to change it. Only the SNA5000 and SNA6000 series offer IF BW 10Hz - 3MHz...
« Last Edit: June 12, 2023, 08:58:37 pm by tomud »
