It might be unnecessary, but I modified procedure of the cross-flash by
electr_petr Post #1619 &
TV84 hex mod from
post #2017It includes everything important.
SSA3021X Plus (FW 3.2.2.5.1R1) to SVA1032X (FW 3.2.2.5.1R1) conversion stepsProcedure for SSA3015X plus to SVA3015X is nearly the same - just lack of bandwidth upgrade
For non-plus there is only online tool license ubnlocking, no cross-flash to SVA, different platform
Prerequisites:• Siglent SSA3021X Plus with FW 3.2.2.5.1R1 (if you have FW 3.2.2.5.1R20, simply download R1 and flash it to downgrade)
• FAT32 formatted USB stick
• network cable
• computer with USB and network connection
• check how to change files with vi editor
https://www.howtogeek.com/102468/a-beginners-guide-to-editing-text-files-with-vi/ (read it carefully)
• SSA3000X+_backup_11411.ADS
https://www.eevblog.com/forum/testgear/siglent-ssa3000x-spectrum-analyzers/?action=dlattach;attach=1217021 • SSA3000X+_telnet_11411.ADS
https://www.eevblog.com/forum/testgear/siglent-ssa3000x-spectrum-analyzers/?action=dlattach;attach=1217022• SVA1000X FW 3.2.2.5.1R1
• TV84 hex mod for FW 3.2.2.5.1R1
https://www.eevblog.com/forum/testgear/siglent-ssa3000x-spectrum-analyzers/msg4403962/#msg4403962• VNA calibration files
https://www.eevblog.com/forum/testgear/siglent-sva1015x-1-5ghz-spectrum-vector-network-analyzer-(coming)/msg3707803/#msg3707803•
I) Initial backup of SSA3021X Plus1. Turn on SSA, put USB stick with SSA3000X+_backup_11411.ADS in the front USB port on SSA
2. Navigate to USB directory, select *.ADS via File -> Open/Load and press Enter
3. Wait until device reboots itself, then turn off, eject USB flash and copy backup files to PC. Total backup size is ~483MB (in my case)
II) Telnet access for SSA3021X Plus & manual backup1) Connect Ethernet cable to SSA3021X and network, configure IP (DHCP option recommended), note IP address.
2) Internal product ID should be 11411. Launch fake update SSA3000X+_telnet_11411.ADS from USB stick to start telnet. SSA hangs with update screen, that's normal.
3) Use Putty (on windows) to telnet to your SSA
telnet <SSA IP address> 10101 (for example, Windows terminal Win+R, CMD works)
4) Backup main directories using commands:
cd /
mount -o remount,rw /usr/bin/siglent/usr/mass_storage/U-disk0
cp -R /usr/bin/siglent/usr/backup /usr/bin/siglent/usr/mass_storage/U-disk0/SA-backup
cp -R /usr/bin/siglent/usr/config /usr/bin/siglent/usr/mass_storage/U-disk0/SA-config
cp -R /usr/bin/siglent/usr/usr /usr/bin/siglent/usr/mass_storage/U-disk0/SA-usr
cp -R /usr/bin/siglent/usr/vnacalikitdata /usr/bin/siglent/usr/mass_storage/U-disk0/SA-vnacalikitdata
cp -R /usr/bin/siglent/firmdata0 /usr/bin/siglent/usr/mass_storage/U-disk0/SA-firmdata0
5) Make files writeable
6) and add telnet server startup line in file “
/usr/bin/siglent/startup_app.sh”:
vi /usr/bin/siglent/startup_app.sh
enter the following line exactly close to the end, just before line "/usr/bin/siglent/Aladdin &"
/sbin/telnetd -l /bin/sh -p 10101 &
7)The end of file will look like:
portmap &
/sbin/telnetd -1 /bin/sh -p 10101 &
echo "startup_app.sh end++++++++++"
7) finalise changes and reboot
sync && reboot
Telnet is active, if you did something wrong there is always backup option for telnet:
1) Open your SSA webpage
2) Sent via SCPI “
DEBTTT” command
3) You can use putty to telnet over port 23
4) Login using username:
root paswd:
ding1234III) HEX Mod firmware FW 3.2.2.5.1R1 using @TV84 instruction & flash1. Download exactly SVA1000X FW 3.2.2.5.1R1 and unpack to your computer,
2. Use notepad++ with hex plugin or other tool to perform hex mod.
3. Look up post 2017, you have to replace in the very beginning of file
41 6D 11 4C 62 2F 9D 2D 48 0A DF 44 D7 B2 FE DD”
With
79 BD EC D2 AB F3 35 A5 E6 F3 58 BF 53 0D 24 8C”
5) Check md5 of the modified file:
3E137F44965CC6205F704E50203EFB276) Flash the new modified firmware
IV) Enable full options on SVA1) Launch online python tool:
https://www.online-python.com/PX3v0J8nbs2) Uncomment
#Model = 'SVA1000X' line (remove #)
3) In you SSA navigate to system info and note HOSTID
4) Input HOSTID into python tool
5) Generate license codes and with SSA menu option System -> Load Option install following options: VNA, ALL, 3032
V) Restore calibration files1) Navigate to
https://www.eevblog.com/forum/testgear/siglent-sva1015x-1-5ghz-spectrum-vector-network-analyzer-(coming)/msg3707803/#msg3707803 and download cali.zip
2) Extract contents to your backup USB stick folder:
\SA-firmdata0\cali3) Connect Ethernet cable to SSA3021X and network, configure IP (DHCP option recommended), note IP address (again)
4) Use Putty (on windows) to telnet to your SSA
mount -o remount,rw /usr/bin/siglent/firmdata0
6) Copy calibration files from USB stick to SSA
cp /usr/bin/siglent/usr/mass_storage/U-disk0/SA-firmdata0/cali/na_1p /usr/bin/siglent/firmdata0/cali/na_1p
cp /usr/bin/siglent/usr/mass_storage/U-disk0/SA-firmdata0/cali/na_2p /usr/bin/siglent/firmdata0/cali/na_2p
sync && reboot
VI) Recalibrate VNA using short/load/open calibration kit
