Hello, I have two questions regarding the SSA3000
The first is general, I am used to using tv analyzers and they all bring spectrum analyzers. Normally the noise floor is usually around 20db. Nowadays almost all the signals are digital, for example, a COFDM signal With 8mhz of bandwidth, that type of signal, in a spectrum analyzer like the one that television analyzers bring, would logically begin to be seen from 20db. The question would be: From what lower level would you start to know that there is such a signal in an SSA3000? We could add the variable of the amplifier but in any case it would be a question of knowing what advantage in terms of weak signals an SSA3000 has over a spectrum analyzer of a normal TV analyzer.
The second question would be to know the dynamic range of these analyzers
Best Regards
