0 Members and 11 Guests are viewing this topic.
Quote from: tv84 on August 13, 2022, 10:11:42 amNo more time to hand in homework...To close things off:"SSA3000X", "SSA3000X_Plus", "SVA1000X", "SSA3000R"Summarizing the collected information :)Script to run:https://www.online-python.com/PX3v0J8nbsAnd added to the attachment (as if the links stopped working).
Quote from: tomud on August 13, 2022, 10:59:43 amQuote from: tv84 on August 13, 2022, 10:11:42 amNo more time to hand in homework...To close things off:"SSA3000X", "SSA3000X_Plus", "SVA1000X", "SSA3000R"Summarizing the collected information Script to run:https://www.online-python.com/PX3v0J8nbsAnd added to the attachment (as if the links stopped working).Weird.On sds3021x (non plus) with factory-enabled tg only EMI and 3032 options worked. AMK and REFL are rejected...Any idea?
tcpsvd -vE 0.0.0.0 21 ftpd /
21 stream tcp nowait root ftpd ftpd /
tcpsvd -vE 0.0.0.0 21 ftpd / -w &
Quote from: tomud on August 13, 2022, 10:59:43 am Quote from: tv84 on August 13, 2022, 10:11:42 am No more time to hand in homework... To close things off: "SSA3000X", "SSA3000X_Plus", "SVA1000X", "SSA3000R" Summarizing the collected information Script to run: https://www.online-python.com/PX3v0J8nbs And added to the attachment (as if the links stopped working).Weird.On sds3021x (non plus) with factory-enabled tg only EMI and 3032 options worked. AMK and REFL are rejected...Any idea?
Jepp, the mistake he made was the option.# Options:# CAT = AMK# Meas = ReflFor AMK he must use CAT as an option also for Refl he must use Meas as an Option.If he take this options everything is fine.regards Chris
otheropt = ('AMK', 'EMI', 'TG', 'Refl', 'DMA', 'AMA', 'WDMA', 'DTF', 'VNA', 'RT40', '3021', '3032', '3050', '3075', 'ALL', 'Meas', 'CAT', '1HZ', '3M')
Hi. I did it. But the system messages says that the key is invalid with CAT or AMK.With Meas, the system inmediatly says that key is invalid and I can't continue.So, I tought that I was doing wrong. But the script worked fine with BW.I have SSA 3021X, it came with FW 2.1.1.1 Maybe the problem is that I updated the FW.RegardsJipo
Do you have any official option license inserted?
But I was unable to know if others key are valid. I belive that they are valid since first time, even without aliases.At this moment, all options work. I don't know if it is because the licence's time is running yet, or the permanent key is valid.
All/any license key is only valid to one instrument and all/any option license status is displayed in the Sys Info as Permanent or trial time remaining in minutes.The status of every license is plain to see.
