Hello,
after upgrading my "SVA1032X" to 3.2.2.5.0.r8, I experience some issues with the VNA, SA not tested so far.
1) When being through the calibration procedure (e.g. 1-port-cal) the "apply calibration" is "on", but garbage is shown on the screen. Cal status is "C?" - see Pic 1. After Switching it to "off" it seems to be working, see Pic 2 of the calibrated load. But it shows "---" in the upper left corner for the cal status.
Did I misunderstand something or is this a bug - somebody else run into the same issue?
2) If I switch on e.g. 10000 points for the VNA stimulus the calibration is only performed and working with max 751 points. Unfortunately are some values in between not - or not correctly - approximated. See pic 3 & 4 which are showing the same 50 Ohm load at identical frq. and span, but with 751 points vs 10000 stimulus. Pic5 is zoomed into 0.1-200 MHz .
3) Maybe I am missing there something, but if I use "User1" as cal-kit, the delay I enter seems to be ignored.
Thanks,
Juergen
