Author Topic: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers  (Read 731544 times)
0 Members and 12 Guests are viewing this topic.
Offline Ghislain
Re: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers
« Reply #1450 on: January 21, 2021, 09:58:22 am »
IP does not change, and I have access to the web interface a all times
May be I am stating the obvious but since you mentioned earlier that a friend helped you with the Telnet session and the vi editing, are you sure you are using the right port (10101) in the configuration of your telnet client?
By default the Telnet port is 23 so you have to adapt that in order to get it connected.
Offline DeepLink
« Reply #1451 on: January 21, 2021, 10:20:43 am »
Yes, all files are unzipped
Ports are correct
The update process is started, but returns to the update screen
No VNA modes available
I tried again with the SVA FW - and this time it rebooted
Still showing SSA (now SSA3032X+), but now the modes VNA and DTF are pressent
Now to the license hack...
« Last Edit: January 21, 2021, 10:34:54 am by DeepLink »
Offline DeepLink
« Reply #1452 on: January 21, 2021, 10:32:30 am »
Got telnet access with SVA1032X_telnet.ADS
but the first command fails
/usr/bin/siglent # $ mount -o remount,rw /usr/bin/siglent/firmdata0
/bin/sh: $: not found
/usr/bin/siglent #
This is where I'm stuck...
Online tv84
  • Country: pt
« Reply #1453 on: January 21, 2021, 10:36:20 am »
So, you converted to SVA. Period. All seems OK.
What do you mean by "stuck"?
Offline tubularnut
« Reply #1454 on: January 21, 2021, 10:48:58 am »
There is no $ at the beginning of the command, that is simply a shell prompt in the original instructions:
This is why you get "$: not found"
It should be simply:
Offline DeepLink
« Reply #1455 on: January 21, 2021, 11:24:50 am »
Yes - Telnet is not my game
Called a colleague and he guided me through the commands
And viola - now its a SVA 1032X, with all options permanent
Thank you so much
P.S. - don't know why it didn't wanted to update, tried several times
Online tv84
  • Country: pt
« Reply #1456 on: January 21, 2021, 11:27:41 am »
Didn't see that.  |O :palm:
Executing some of these procedures when we don't have the ability to debug such an error is likely to originate some headaches or "pocket aches"...
Offline arturfra
« Reply #1457 on: January 21, 2021, 10:12:14 pm »
SVA1032X Firmware – V3.2.2.4.0 (Release Date 01.20.21 )
The following users thanked this post: tubularnut, Johnny B Good, Kibabalu, MOTechGuy
« Reply #1458 on: January 21, 2021, 11:33:53 pm »
Firmware update for all SSA3000X Plus models....please ensure you select the correct version for your instrument.
Version: V3.2.2.4.0
https://int.siglent.com/download/firmwares/?ProId=48
~19.3 MB
Release notes
This version can not be rolled back
Fix TG switch error at small RBW
Fix Help and Limit file lost when Factory reset
Fix CNR calc error when no peak found
Fix OBW result overflow
Fix Harmonic calc error at 100Hz RBW
Fix Reflection Open+Short calibration action
Fix spectrum amplitude error in DMA mode
Optimize EMI .csv file content to all signal list
Optimize EMI peak search
Optimize Auto cal process
Add Peak search to Spectrum in DMA mode
The following users thanked this post: Johnny B Good, MOTechGuy
Offline Ghislain
« Reply #1459 on: January 22, 2021, 10:25:18 am »
Upgrade worked flawlessly, first time I saw a 'upgrading now' message including an animated hourglass, took about a minute including the auto reboot  :-+
Online tv84
  • Country: pt
« Reply #1460 on: January 22, 2021, 10:54:42 am »
WARNING for all crossflashers regarding this latest version.
The following users thanked this post: KermitDK, rmaranhao, tomud
Offline tomud
« Reply #1461 on: January 23, 2021, 02:59:20 am »
To be sure, the second nand backup was made (the first was as SSA)...
...and we are waiting for what will happen :P
1155988-0
I haven't tested the firmware yet (it's late and I'm going to sleep).
For every complex problem, there is a solution that is simple neat and wrong...
Offline MOTechGuy
« Reply #1462 on: January 24, 2021, 04:43:39 pm »
3.2.2.4.0.r2 is working 100% on my SVA1032X (SSA3021X Plus with pro mode features).  Also, it fixed the Reflection calibration issue!  Additionally, it fixed a weird freeze up issue when I would go to the DTF option after using the VNA
If you aren't worried about telnet and make a backup, an upgrade should be safe.  I mainly upgraded as I needed the Reflection option to work properly
« Last Edit: January 24, 2021, 04:46:42 pm by MOTechGuy »
Offline tubularnut
« Reply #1463 on: January 24, 2021, 05:08:57 pm »
3.2.2.4.0.r2
Where did "r2" come from then ??
Offline KermitDK
« Reply #1464 on: January 24, 2021, 07:18:09 pm »
3.2.2.4.0.r2
I did the same as MOTechGuy, and also got 3.2.2.4.0.r2
Offline tubularnut
« Reply #1465 on: January 24, 2021, 07:19:24 pm »
3.2.2.4.0.r2
Did you download from int.siglent.com ?
« Reply #1466 on: January 24, 2021, 07:29:03 pm »
3.2.2.4.0.r2
Related to the cross flash I'm guessing as it's not available on official Siglent sites.
Offline tubularnut
« Reply #1467 on: January 24, 2021, 07:32:22 pm »
Ok  :-+
Offline KermitDK
« Reply #1468 on: January 24, 2021, 07:38:35 pm »
3.2.2.4.0.r2
I agreee, I did download the SVA1032X_V3.2.2.4.0_EN, so it must have something to do with the cross flash.
But I think that next time I see an upgrade, I would remember to make a nand backup first. But thats too late now, and it seems to be working :-)
« Reply #1469 on: January 24, 2021, 07:57:39 pm »
I suspect it's a little flag added by the SW engineers.  ;)
Offline KermitDK
« Reply #1470 on: January 24, 2021, 08:04:32 pm »
Yes - and at next upgrade, it will become a 4½ digit multimeter  ;D
The following users thanked this post: tv84
Offline Elasia
« Reply #1471 on: January 24, 2021, 08:05:15 pm »
The r2 is from using pro mode and not actually have entered license keys... nothing to do with cross flash itself
Offline tubularnut
« Reply #1472 on: January 24, 2021, 08:15:37 pm »
I think I understand, I actually entered the keys on mine, with a little help  ;)
Offline Dwaine
« Reply #1473 on: January 30, 2021, 06:43:46 am »
Just bought a SSA3021X plus.  I have upgraded it to a SVA1032X.  I was able to flash the unit with the newer firmware V3.2.2.4.0  successfully.
I noticed that the any of the telnet ADS don't work anymore?
The following users thanked this post: Lupusz
Offline Dwaine
« Reply #1474 on: January 30, 2021, 06:49:07 am »
I also had to mount the usb drive in write mode.
mount -o remount,rw /usr/bin/siglent/usr/mass_storage/U-disk0
