I came across something useful for myself – at least a ‘hands free’ way of investigating circuit behaviour
My question is if something similar can be implemented (if not already) that can be used for SSA’s
– especially when matched impedances are required
– not to mention much higher frequencies than typical with MSO’s
It’s possible to fabricate a suitable cable with an appropriate termination at the SSA end
Can we do same at the probe end?
I guess it’s a matter of simply trying to see what the frequency response will be – using the SSA itself ??
We can create two cables terminated at the TG and SSA input using suitable N terminations
– then simply ‘tune’ the 'probe end' and if not perfectly flat response for the entire 3.2G span
– normalize it before use
This should work I guess for TG sweeps … but if just ‘probing’ with SSA input alone will we have any problems??
Has anyone attempted something similar?
Any feedback welcome
