Author Topic: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers  (Read 749055 times)
stoepie2002 and 2 Guests are viewing this topic.
Offline rhb
Re: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers
« Reply #875 on: May 12, 2020, 10:02:49 pm »
I bought a Siglent SSA several years ago.  It was so buggy I returned it.  I now have an 8560A and 8566B.  Much happier.  The Siglent had more "features", but I'd rather have reliability.
Reg
Offline Elasia
« Reply #876 on: May 13, 2020, 10:35:00 am »
I present to you a SSA fully optioned up including the hidden features
Big thanks to tv84 for his decryption work
The following users thanked this post: TrAndy
Offline Sighound36
« Reply #877 on: May 13, 2020, 11:42:55 am »
As always Tv84 doing his thing  :-+
So the big question is can you obtain the VNA on this model as well?
Offline TurboTom
« Reply #878 on: May 13, 2020, 11:46:00 am »
Look at @Elasia's third image: here he's measuring S11. Also the option list includes "VNA" option...
Maybe it's time to consider selling my "old, improved" SSA3021X for an option-up  ;). This liberated "Plus" should cover 95% of the cases where I otherwise would power up my 8753C...
« Last Edit: May 13, 2020, 11:50:51 am by TurboTom »
Offline tubularnut
« Reply #879 on: May 13, 2020, 12:04:48 pm »
Think I'll hold back on buying the SVA in addition to my Plus!
Offline Elasia
« Reply #880 on: May 13, 2020, 12:06:33 pm »
Yeah it looks gtg with the exception of needing to calibrate it
You also need this kit to do that
 http://www.saelig.com/product/f503me.htm
Also this requires more moderate knowledge as its not just enabling option keys and makes it not compatible with future updates without rework
The tools needed are not public to my knowledge either
Offline Houseman
« Reply #881 on: May 14, 2020, 03:41:26 pm »
ADC Overload but graph not displaying peak.
Hi. During a EMI measurement my SSA 3012X was beeping as mad telling me there was an ADC overload but apart from that I could not find the frequency peak that caused the OL nor anything else pointing me to the right direction.
It is normal that even with a ADC overloaded input the monitor does not show anything?
Am I missing something in the setup?
Best regards and thanks
Offline TurboTom
« Reply #882 on: May 14, 2020, 04:19:18 pm »
The signal swamping your SSA's mixer may actually be located outside of the observed frequency span so it's not directly visible on-screen. Increase the span to locate it.
The error message "ADC overload" is somewhat misleading. The problem isn't that much the ADC but rather the first stage mixer being operated outside its linear range. And since there's no additional filtering present (except for the fixed low-pass filter that cuts input frequencies above the specified range of the SSA - 3.2x GHz -), a strong signal outside the span that you look at may very well drive the mixer into its non-linear range. It's good practice to always start with full span, then adjust the input attenuation, and only after that zoom down to the frequency range that you want to observe.
« Last Edit: May 14, 2020, 04:29:22 pm by TurboTom »
Offline Houseman
« Reply #883 on: May 14, 2020, 04:44:44 pm »
Thank You TurboTom (not also for this reply.... ;) )
Do you mean those peaks multiple of 50Hz are causing the ADC overload?
Offline TurboTom
« Reply #884 on: May 14, 2020, 08:25:52 pm »
@Houseman: No, sorry, I may not have been completely clear -- please start with measuring the full span, i.e. select "Span" -> "Full Span". This should select, depending on the specific model of the SSA you're using, a frequency range of 0 to 2.1 or 3.2GHz. If the Resolution Bandwidth setting is set to auomatic, the scan time shouldn't be overly long. If the scan is too slow, change the VBW to automatic or a higher, fixed setting.
Now you should be able to identify the peak that's overloading your SSA and adjust the input attenuation accordingly to eliminate the warning (a margin of at least 10dB should be kept, when you need high spur rejection, even 20dB may be necessary). Then "magnify" the span to the range that's of interest to you and adjust the other parameters accordingly (RBW, VBW if required). You may "play" with the attenuator setting to identify possible intermodulation spurs (if there are, they should vary with the attenuation, otherwise, only the noise background will shift up/down) and find the best setting to conduct your measurement.
Offline tubularnut
« Reply #885 on: May 15, 2020, 03:00:54 pm »
By request, screenshot of unlocked 3021X-Plus
991866-0
« Reply #886 on: May 15, 2020, 03:06:33 pm »
Hmmm, not quite as interesting as the one from Elasia a few posts back.  :popcorn:
Online tv84
  • Country: pt
« Reply #887 on: May 15, 2020, 03:06:45 pm »
Assuming I'm 4 years old, who can explain me the differences between:
Siglent SVA1032X
Siglent SSA3032X Plus
Also, is there a SSA7075X Plus? Or the 7.GHz is a SSA3032X Plus on steroids?
The following users thanked this post: Sparky
Offline tubularnut
« Reply #888 on: May 15, 2020, 03:13:33 pm »
Mine was unlocked back in December  ;)
« Reply #889 on: May 15, 2020, 03:14:16 pm »
SSA3075X Plus and SVA1075X are new HW AFAIK.
Also SSA3000X-R models of 5 and 7.5 GHz might be new HW too ?  :-//
Offline jemangedeslolos
« Reply #890 on: May 15, 2020, 04:01:16 pm »
Im coming  >:D
 :popcorn:
« Reply #891 on: May 15, 2020, 04:13:14 pm »
Elasia :
Where did you buy your SSA3021X ?
Is it from Batronix in Germany ?
Thank you  :)
Offline Elasia
« Reply #892 on: May 15, 2020, 04:56:02 pm »
Elasia :
Thank you  :)
Saelig on this one, i got my new SDS2100X Plus scope from batronix though because they were the only good folks that had one and the blog discount :P
Offline Elasia
« Reply #893 on: May 15, 2020, 04:57:47 pm »
What about my 4-year old question?  :)
Just like tau said.. its a different hardware platform im pretty sure as well from everything i could read on it.. also this one is limited by hardware design that TSP goes over in his breakdown, so yeah no 7Ghz here
Offline Elasia
« Reply #894 on: May 15, 2020, 05:00:46 pm »
Siglent SVA1032X
Nothing hardware wise is different other than the label on the plastic.. software wise.. i know you know :P Up to you if you reveal it
Also I just confirmed that the electronic loads are all the same too, im going to get the cheap 200W and convert it to a 300W as my next project
Online tv84
  • Country: pt
« Reply #895 on: May 15, 2020, 05:02:29 pm »
I was asking the differences between these 2:
Siglent SVA1032X
« Reply #896 on: May 15, 2020, 05:13:13 pm »
It's a bit off topic, but if tautech was really a nice guy, He would have bought each model from Siglent with detailed teardown.
Only on SDS5000X, if it turns out that now the front end is the same on the whole family, it would double sales of this model for Siglent  ;D
Offline Elasia
« Reply #897 on: May 15, 2020, 05:18:18 pm »
Siglent SVA1032X
1:38 mark
It's the same specs
the one that is subpar is the SVA1015X and is the older platform
I dont recall seeing anyone having a pic or video of a SSA3032X Plus in the wild
The following users thanked this post: tv84
« Reply #898 on: May 15, 2020, 05:22:27 pm »
Registering on this forum was the most dangerous decision for my money wallet  :rant:
The following users thanked this post: Qw3rtzuiop
Offline Elasia
« Reply #899 on: May 15, 2020, 05:29:49 pm »
Hahahahah I know right...
