d scenery or what ever art pictures using JPG but this is not suitable for this kind of technical document images.
That is not correct. JPEG can provide a similar image quality as PNG, but it depends on the parameters (i.e. quality level, compression factor) that are used for generating them. If the screenshots in JPG are inferior in quality to PNG shots then this isn't the fault of JPEG but of Siglent because they set the JPG parameters in their firmware to low quality.
[/quote]
Not at all if we look result file size.
Original TFT BMP is 1843254 bytes.
Perhaps need some lesson? PNG is a lossless compression format when JPG is lossy.
You can try your self some exercises if you never have done.
After convert SSA 1.8M BMP to PNG so that PNG file size is around 30k. Look result. (file size depends what you have in picture, because it IS lossless. But also this is why it pack well this kind if images where image do not have nearly anything)
Then do same using conversion to JPG so that result is around same file size. Look result.
But, if you take normal camera image situation is very very different if look PNG and good quality JPG file sizes. In this case JPG win 10-1. Also in normal photograph, it is not so criticalk (usually( if we loose something..
And vice versa... in this kind of SSA etc technical images, mostly PNG win JPG like 10-1.
These things is best you self study using example google and read.
But in other hand, everyone has the right to choose a religion, and it must be respected.
Of course if we use very high quality settings for JPG package result is quite good, also for this kind of images, but why we then use packing if file size is big when we can get still better quality with lot of smaller file size.
Do you think we want out from BMP just because file size. Best result is with PNG and difference is not even only marginal.
Here attacehed two images.
Exatly same. Same BMP converted ti PNG and JPG. First I think I try pack JPG to ssame size as PNG size here but result was so terrible that then I select around double file size for JPG paackgage result.
BMP is too big here but even with high zooming I can not find difference between this original BMP and this PNG.
But if you zoom in to JPG it is like pixel porridge. And note, it compressed file size is still over 2x PNG
Do not look what image show, look only image quality. (experiment what you see in image is not what you get from Siglent directly, but 10MHz carrier level is 0dBm)
![](https://www.eevblog.com/forum/testgear/siglent-ssa3000x-spectrum-analyzers/?action=dlattach;attach=250746;image)
Load, then zoom both 5x and compare.
