Before doing something silly ..
I noted that in the SVA there are TWO
firmdata files
firmdata0and
firmdata1What is the expected structure in the SVA ?? - I recall the SSA had only one firmdata file -
firmdata0Second observation is that the
firmdata0 and
firmdata1 content seems to be identical ??
AND
The SVA
firmdata0 NSP_sn_bandwidth.xml content is IDENTICAL to the same file in the SSA firmdata ??
Is the firmdata in the SVA the 'leftover' from the SSA??
It seems to be that the stock SVA firmware does not have license file info - presumably this is loaded onto the device at a later (post firmware) stage??
If so, this would make sense as it appears the SVA
NSP_sn_bandwidth.xml file contains the SSA license data only.
In my case because it was an untouched SSA3021x Plus - there are no SVA options visible in the file
Question is ...
What are the SVA various options legit 'license tags' that can be added into the current
NSP_sn_bandwidth.xml file??
Am I on the right track here or simply
Would be nice to understand this before going further
EDIT: When you take you time and try to understand what's sitting in front of your eyes - eventually everything falls into place - all good - another successful SVA crossflash with all options enabled about to happen
