Author Topic: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers  (Read 731444 times)
0 Members and 16 Guests are viewing this topic.
Offline EEVblog
Re: Siglent SSA3000X spectrum analyzers
« Reply #175 on: June 16, 2016, 03:28:49 am »
IMHO it is difficult to tell what makes a good review. From a technical buyers perspective I'd like to see a full functional test (especially when it comes to Chinese equipment) so at least I can see it works and how easy it is to operate. However such a video would be boooring  :=\  :=\ where was I... oh reviews... All in all I think Dave has to make a tradeoff between showing all the ins & out versus a cursory look to show a device exists and what the pros & cons are when compared to similar products.
Those are usually two different types of videos. A "first impressions" video for want of a better term is literally me turning the camera on taking it out of the box and dicking around with it, I have never used it before. The video ends up being what it is. People don't have to like that style, but it lets me get a video out quickly within a matter of hours.
Review videos have more thought and a lot more hours put into them. For example the Rigol 1054Z review where I did a 1:20min feature review, and a shorter 13min summary review, plus a teardown video. And I still didn't cover everything.
Every review is going to be a tradeoff in some way.
Offline EEVblog
« Reply #176 on: June 16, 2016, 03:32:26 am »
Dave functions best when he follows his own motto - "Don't turn it on, take it apart". I find the internal shots and details of the electronic equipment a thousand times more interesting then seeing a basic functional review. It is also generally easier to find someone who shows off the user interface and functions versus seeing what makes a device tick internally as many people are afraid to take stuff apart.
IIRC teardowns usually get more views than the reviews.
So Dave, don't turn it on(we'll leave that to Shahriar), take it apart!
There is no "we'll". I do what I want, other bloggers do what they want.
Offline EEVblog
« Reply #177 on: June 16, 2016, 03:33:48 am »
BTW, I think probably the best way to "review" the SSA is to compare it with the Rigol DSA, as they are basically the only two units on the market in this price point.
Offline hendorog
« Reply #178 on: June 16, 2016, 07:22:29 am »
It would be good to get an SA44B in there as a wildcard if you can get one?
It's cheaper - although USB based so you need a PC. It has much better specs than the Rigol, and is comparable with the Siglent.
https://signalhound.com/products/usb-sa44b/
Offline tautech
« Reply #179 on: June 16, 2016, 08:42:22 am »
Sorry, have done literally nothing with it apart from turn it on for the photo.
But from that, great big screen, heavy, fan a bit annoying, and cheapish look'n'feel on the plastic case.
Heavy is good, heavy is reliable  ;D
I checked the datasheet, it's not that heavy:
contain tracking generator 4.60 kg(10.1 lb)
In fact little more than a DSA815:
With Tracking Generator
4.25 kg (9.4 lbs)
Online nctnico
« Reply #180 on: June 16, 2016, 10:08:39 am »
It wouldn't hurt to put an HP/Agilent/Keysight or Advantest spectrum analyser next to it.
Offline rf-loopTopic starter
« Reply #181 on: June 16, 2016, 04:39:07 pm »
Example Keyshit N9320B 3GHz is perhaps technically somehow comparable.
Here attached bit more carefully done test for imagine something about SSA3000X phase noise so that also with exactly same settings result is checked using other enough known signals and they all match well enough for this purpose.
Why there is unvisible trace C (Math). This I will explain later but this is how I can jump over forced Detector setting in Marker function  Noise (if I do not this, result is more nice but imho, too optimistic) Math do nothing but just Trace A + 0dB. But when select Marker fn Noise it do not matter if it change trace C detector setting. After then I can move cursor source from trace A and I can keep dBm/Hz and use what ever Detector mode in cursor source trace. (I hope they disable this Detector forcing and think that User is Mastera nd equipment is slave. I do not like equipments what try play as Master over me. ;)
« Last Edit: June 16, 2016, 04:48:17 pm by rf-loop »
Offline cio74
« Reply #182 on: June 16, 2016, 04:44:28 pm »
Has anyone published anything yet, I have the damn thing in the basket for a couple of days now, got to click the 'Checkout' button...
Offline EEVblog
« Reply #183 on: June 17, 2016, 03:06:43 am »
Tg option is here:
http://www.siglent.eu/catalog/product/view/id/1111/s/siglent-tg-ssa3000x-tracking-generator-license/category/98/
That option sounds like a mere softtware licence key, does it mean that the instrument come anyway with TG HW installed and it's only matter to activate it, even after the purchase ?
Yes. TG option is only $169, a no-brainer decision.
I got these prices quoted:
SSA3021X
9KHz-2.1GHz, Phase Noise<-98dBc/Hz, RBW 10Hz-1MHz, Min. DANL -161dBm/Hz, Total Amplitude Accuracy<0.7dB, 10.1 lnch WVGA?1024x600?Display
$1,595
SSA3032X
9KHz-3.2GHz, Phase Noise<-98dBc/Hz, RBW 10Hz-1MHz, Min. DANL -161dBm/Hz, Total Amplitude Accuracy<0.7dB, 10.1 lnch WVGA?1024x600?Display
$3,295
TG-SSA3000X
Tracking Generator Kit
$169
EMI-SSA3000X
EMI measurement kit
$559
AMK-SSA3000X
Advanced measurement kit ,including ACPR, CHPower, OBW and so on.
$465
Refl-SSA3000X
Reflection measurement kit
$429
UKitSSA3X
Utility Kit: N (M) -SMA (M) cable, N (M) -N (M) cable, N (M) -BNC (F) adaptor (2 pcs), N (M) -SMA (F) adaptor (2 pcs), 10 dB attenuator
$259
RBSSA3X20
Refl-SSA3000X, RB (1 MHz~2 GHz), N (M) -N (M) adaptor (2 pcs)
$559
SRF5030
Near Field Probe Set (4 pcs), N(M) -SMA (M) cable, N(M) -BNC(F) probe
$660
N-SMA-6L
N-SMA cable, 6GHz bandwidth
$49
N-N-6L
N-N cable, 6GHz bandwidth
$49
N-BNC-2L
N-BNC cable, 2GHz bandwidth
$39
SEM5040A
LISN
$1,885
Offline EEVblog
« Reply #184 on: June 17, 2016, 03:14:37 am »
Playing with it now.
Both set to 1.5GHz span and same attenuation settings.
The Siglent is an almost exact copy of the Rigol menu system! (not the first time they have done this, they have copied Keysight before)
Offline ebclr
« Reply #185 on: June 17, 2016, 03:40:10 am »
I am eagerly waiting for the results of this comparison in your videos
Did you bought both ?
Offline EEVblog
« Reply #186 on: June 17, 2016, 03:48:00 am »
No, both are on loan.
Offline EEVblog
« Reply #187 on: June 17, 2016, 03:52:20 am »
The UKitSSA3X utility kit is very nice. Comes with response test result, as does the individual cable option for $49
Offline tautech
« Reply #188 on: June 17, 2016, 04:11:11 am »
Seems crazy to me that the UKitSSA3X utility kit at the above listed price of $259 doesn't come in a $2 plastic box but in a cardboard one.  >:(
Siglent or their supplier of these accessories needs to do better IMO, someone's gone to the trouble of making a custom foam inner that probably cost more than a decent box.  ::)
« Reply #189 on: June 17, 2016, 04:29:37 am »
Is this SSA3000X what you use for playing with SA equipped with new or old HW (afaik, main difference is TG)
If  last 6 numbers of serial number  is over  160100 (In some old information 160110) then TG is new improved version.
Is it normal selling version or distributors early phase demo version?
Offline EEVblog
« Reply #190 on: June 17, 2016, 04:56:26 am »
Serial 2160239, May 2016 build.
It is the new one with the revised hardware. From what I have heard it's the front end they had to revise.
The following users thanked this post: kado
Offline nugglix
« Reply #191 on: June 17, 2016, 05:10:42 am »
I looked at Batronix and siglent.eu, they don't even list the UKitSSA3X option.
Anyone knows if this is a new addition to the options?
Offline PartialDischarge
« Reply #192 on: June 17, 2016, 05:14:38 am »
Theres a +20dB noise improvement right there... cio74 you should just hit "buy" with confidence, ask for the latest HW though
Offline TheSteve
  • Living the Dream
« Reply #193 on: June 17, 2016, 05:20:17 am »
How much does the noise floor change with the preamps enabled?
VE7FM
Offline tautech
« Reply #194 on: June 17, 2016, 05:24:24 am »
They're all listed in the datasheet and on the Siglent websites:
http://www.siglentamerica.com/USA_website_2014/Documents/DataSheet/SSA3000X_DataSheet_DS0703X-E03A.pdf
http://www.siglentamerica.com/pdxx.aspx?id=1546&T=2&tid=227
Offline Dubbie
« Reply #195 on: June 17, 2016, 05:32:43 am »
Dave have you checked out the new Rigol E variation?
http://www.emona.com.au/products/electronic-test-measure/rf-test-equipment/dsa-832e-865.html#.V2OKxvl97AQ
Wonder how that compares to the Siglent.
Offline cio74
« Reply #196 on: June 17, 2016, 05:38:51 am »
I just did (ask which HW version/production date I will get) after reading the latest posts :)
Offline EEVblog
« Reply #197 on: June 17, 2016, 06:20:52 am »
Hadn't seen that.
Vastly better DANL than the regular one, but the price doesn't make it a comparison.
« Reply #198 on: June 17, 2016, 06:32:03 am »
If you read specs and if you read this thread there is also some real tests
~20dB.
Offline EEVblog
« Reply #199 on: June 17, 2016, 06:36:10 am »
Both with preamps on (Siglent is 20dB vs 10dB on Rigol)
At 1MHz and 10KHz RBW
« Last Edit: June 17, 2016, 06:50:49 am by EEVblog »
