Help !
So, last night I updated my SSA3032XS Plus to a SVA1032X.
And at first glance, everything looked great.
But today, I realized that none of the VNA functions work. All I get is garbage.
Attached is a smith chart with a 50 ohm load attached. This should give me (almost) a dot at the center of the chart.
No matter what I do, calibrate, change to other measurements, everything in the VNA Mode is garbage.
The SSA mode appears to still work, as well as the TG.
I opened my unit to check for the missing cable, and it was there. While at it I also attached a cable for
the UART and can see the thing boot now, etc.
The worst of it all, I can not longer telnet in to the unit. Even the telnet ADS that used to work, have
stopped working. I tried static IP and DHCP, same result.
I am completely puzzled.
Any ideas/suggestions ?
Many Thanks,
rudi
