There are in fact TWO forms of EMI
One is a basic EMI that is limited to you having to use it in scanner mode over your given range
the other is REAL TIME EMI and is the 6th option in the mode list for a real time SA
That is what you are seeing
Interesting ...
So there is a real-time SSA (as advertised by Siglent - currently the 7.5GHz device)
There is about to be released (if not already) SVA that has 7.5GHz capability - I presume it has same HW as the SSA , a justifiable guess.
So the option 'for sale' for the
non-real-time SVA (what we end up having via the crossflash of a SSA3000X Plus device) is the basic EMI you are referring to??
If so, this would make sense, since the 'proper' licensing will not enable the real-time SVA options in the
Mode menu.
BUT
If this is true - and no reason why - then how and where is the 'for sale' option that is enabled on the non-real-time SVA evoked or deployed / used ??
Sorry if this is an obvious mode in the SVA operation - I simply did not have time to enjoy the SVA and start fiddling with its numerous functions.
Natural instinct - is to expect a special menu 'option' if you are parting with $500+, or at least be able to see what you 'bought' visually, and not just having the ability to connect to some internal analysis signals / data?
Would be nice to get to the bottom of this dilemma
Perhaps expectations are clouding the 'electronic function' which is there in front of our eyes - we (more likely I) simply can’t see it yet
EDIT: OOPS .. we cross posted - yeah can see the EMI within the submenu - intereting to see if the EMI license is disabled - what happens to the resultant menu??
