Author Topic: Siglent SPD3303X and SPD3303X-E Power Supplies  (Read 842 times)
Online KungFuJoshTopic starter
  • TEAS is real.
« on: June 20, 2024, 03:09:51 pm »
I couldn't find a generic thread for the SPD3303X, so I made this.
I got a used SPD3303X (real, not hacked) for a decent deal on fleabay. It was only powered on 5 times, which is amazing since I nearly tripled that in a few minutes messing with IP and USB connections.
Anyway, it came with the 1.01.01.02.07R2 firmware, and Siglent's site has the newer version 1.01.01.03.10, and I want to upgrade to that. It doesn't work though. I tried upgrading and it gives the error "The file does not match the device!" What gives? Is that only for a different hardware version?
Thanks,
Josh
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Online tv84
  • Country: pt
Re: Siglent SPD3303X and SPD3303X-E Power Supplies
« Reply #1 on: June 20, 2024, 03:13:13 pm »
Are you flashing with a patched app or the original app?
  • TEAS is real.
« Reply #2 on: June 20, 2024, 03:19:12 pm »
The original app, but this isn't a hacked X-E, it's the official X model.
Offline Mortymore
  • Country: pt
« Reply #3 on: June 20, 2024, 03:26:07 pm »
The 1.01.01.03.10 firmware version only support s V6.1 hardware version, and yours is v3.0
The following users thanked this post: tautech, KungFuJosh
  • TEAS is real.
« Reply #4 on: June 20, 2024, 04:15:08 pm »
Thanks, that's what I figured. I was wondering if there was any reason that the newer hardware might have an improvement, but I'm guessing it was maybe a supply chain related change. 🤷
« Last Edit: June 20, 2024, 06:29:11 pm by KungFuJosh »
  • TEAS is real.
« Reply #5 on: June 20, 2024, 06:48:08 pm »
I'm impressed with this so far. Voltage/readback accuracy says 0.03% of reading+10mV, and I'm seeing it within ~1.7mV on my SDM3065X.
  • TEAS is real.
« Reply #6 on: June 21, 2024, 04:03:38 am »
It turns out I had one channel within 2mV, and the other was much farther off (but still within spec of 0.3% + 10mV)...but that wasn't good enough for me (translation: my entertainment) so I decided to do the calibration crap for it.
Did Siglent try to make calibration harder for some reason? They removed it from the newer version of the service manual, and I had to downgrade to .05 fw to get the cal commands to work. But they did!
Now everything is dead on across the board on both channels. Max variance is between 0.5mV to 1mV, usually on the money though. Cal carried over fine when I upgraded back to .07R2 fw.
Offline tautech
« Reply #7 on: June 21, 2024, 05:21:22 am »
(Attachment Link)
V6 HW includes the updated rectifier bridge and a slightly improved/better display when in Series or Parallel modes.
As below.
This thread has info on the older HW rectifier bridge failure and recommended remedy:
https://www.eevblog.com/forum/repair/siglent-spd3303x-e-reboot-problem/
Online mawyatt
« Reply #8 on: June 21, 2024, 03:29:29 pm »
@ Josh,
Were you able to get LAN access?
Best,
~Wyatt Labs by Mike~
  • TEAS is real.
« Reply #9 on: June 21, 2024, 03:36:23 pm »
LAN access was no problem. There was one weird bug with it though. The default address is 192.168.0.100. I changed that to a different number, and when I went to do the fw update over LAN, it still showed 192.168.0.100 as the address for the update (on the fw update screen specifically). So I switched it back to .100 and left it static that way, and had no other issues. Firmware updated twice over LAN without issue.
Even with DHCP on, it still chose the same address. If your LAN is 192.168.1.XXX or some other variation that could be an issue, I don't know whether the fw actually has an issue with IP addresses or not.
« Last Edit: June 21, 2024, 03:47:46 pm by KungFuJosh »
Offline Mortymore
  • Country: pt
« Reply #10 on: June 21, 2024, 03:51:37 pm »
I have the router setting the IPs for the devices, by MacAddress.
  • TEAS is real.
« Reply #11 on: June 21, 2024, 04:02:30 pm »
Sounds like a Netgear?
What's the IP for your PSU(s)?
Online mawyatt
« Reply #12 on: June 21, 2024, 04:06:38 pm »
Can get LAN access with all 3 PS we have with EasyPower, but can't "see" them with NI-MAX or NI-VISA. We can "see" the SDM3065X with NI but not the three SDP3303Xs??
Best,
  • TEAS is real.
« Reply #13 on: June 21, 2024, 04:09:04 pm »
I used Putty via telnet on port 5025 to do the calibration stuff. NI-Max was too much effort to even consider. 😉
Offline Mortymore
  • Country: pt
« Reply #14 on: June 21, 2024, 08:26:55 pm »
My router is a TPlink Archer C7, but I don't think that matters, since I believe any reasonable router has an IP address reservation table (under DHCP options)
For easy memorisation, I  tend to attribute IP addresses based on the device reference (SDM3055 --> IP 55)
For instance:
ID    MAC Address                   Reserved IP Address
1   74-5B-C5-xx-xx-xx          192.168.0.33   ---> SPD3303
2   00-22-24-xx-xx-xx          192.168.0.74   ---> IDS2074
3   CC-33-31-xx-xx-xx          192.168.0.55   ---> SDM3055
4   C4-F3-12-xx-xx-xx          192.168.0.32   ---> SDG1032
  • TEAS is real.
« Reply #15 on: June 21, 2024, 09:16:01 pm »
In one way or another, yes. But Netgear (at least used to) have some interesting additional choices for static routing beyond that.
My current router is an Amplifi Alien, and it's interesting. You can look at the list of connected devices and manually enter a static IP after clicking on a device. No need to go through a bench of menus to set stuff like that.
Have you ever updated firmware over ethernet with those IPs? Or are they all the newer hardware?
  • TEAS is real.
« Reply #16 on: June 26, 2024, 06:19:31 pm »
I'm concerned about the V3 hardware in my SPD3303X. I want to stress test it to see if it will survive or not.
What would be a good stress test for this? I don't currently have an electronic load, but I'm not opposed to getting one.
Thanks,
Josh
Offline tautech
« Reply #17 on: June 26, 2024, 08:34:47 pm »
Their only weak point is the 2A bridge used in earlier HW. The earliest ones gave no problem but bridge supplier may have been changed and then they very occasionally gave trouble.
A faulty unit we swapped out was repaired and we stress tested it at 5A @ 32V (Parallel mode) into a Eload for 3 days while at EMEX.
It provided some localised heating.  ;D
Online 2N3055
  • Country: hr
« Reply #18 on: June 27, 2024, 05:32:56 am »
Thanks,
Josh
You get a load and then you stress test both at the same time?
