Author Topic: Can you post an .ARB file if you have a Rigol Signal Gen?  (Read 1909 times)
Offline alank2Topic starter
« on: October 09, 2015, 10:10:03 pm »
I'd like to look at the format of what it creates when you make a waveform manually like the manual recommends.  If someone could go in, set an amplitude, create an arb, maybe set it to 3 points and put 3 points in and then save it to file.arb and post it that would be cool.  Thanks!
