Author Topic: Siglent SPD3303D series bug  (Read 14377 times)
Offline Salas
  • Country: gr
Re: Siglent SPD3303D series bug
« Reply #25 on: July 08, 2015, 10:05:16 am »
Hey, thanks. Fine could be assisted by the <--- ---> buttons to just select any next digit for changing.
Offline Siglent
  • Country: cn
  • SIGLENT
    • SIGLENT TECHNOLOGIES
« Reply #26 on: July 08, 2015, 10:10:02 am »
at serial mode, both Channel 1 and channel 2 still have output, so I don't think this display mode is better.
The Best Value in Electronic Test & Measurement
Offline Salas
  • Country: gr
« Reply #27 on: July 08, 2015, 10:23:54 am »
Dear Siglent, no need to press ON before fully setting with track and then change to independent.
Some Instek models do that also i.e. displaying same current in series mode on both channels ref CH1. Which is clearly wrong when the loading between common node and halves can very well be unequal. Must be addressed. That, and 1V coarse step too, so the Siglent PSU models will be complete for function and measurement. On all other fronts they are very good products indeed, I am happy with mine.
Offline rosbuitre
  • Country: ar
« Reply #28 on: October 09, 2015, 09:21:43 pm »
Hi
Install new version of Easypower P12 for my SDP3303D and the EasyWave P32 and don't work, the previous function OK
Regards
My instruments: DMM Keysight 34461A / Tektronix DMM916 / Fluke 12, Rigol DS1074Z, Deer DE-5000, Siglent SDG805 / SDP3303D, Dayton Dats2
