Author Topic: Siglent SNA5000A two and four port VNA's  (Read 20107 times)
Offline tautechTopic starter
Re: Siglent SNA5000A two and four port VNA's
« Reply #75 on: November 08, 2023, 06:55:31 am »
« Reply #76 on: March 27, 2024, 01:26:55 am »
SNA5004A
Member EE-digger asked for some HPAK Cal kit support screenshots.
15 HPAK Cal kits are supported.
Cal kit used F603FE Female 4.5 GHz 3.5 mm at the end of 500mm So-So cheap SMA cable connected to N-SMA adapter on N type port. Basic SOL Cal performed.
Offline EE-digger
« Reply #77 on: May 12, 2024, 02:04:08 am »
Thanks for those images, Rob.
I received my new SNA5000A the other day and the VNA side is excellent, everything I had hoped it would be to replace an Agilent PNA.
The VNA menu flow will take some getting used to.  Agilent was always about the best on the market, except for markers which always sucked.  Siglent's markers are a little bit better, but different.
To me, S11 noise floor (directivity) immediately after a cal is a good indicator of instrument quality.  The SNA returns a nice < -70 dB across the range.  The SVA1032X, for comparison, returns typically -55dB with the same cal kit.  The cal also appears to be quite stable over several hours, probably more.
The VNA port extensions and fixturing look very good.  Spent time with the port extensions and was pleased to find AUTO open or short extensions.  I'm experimenting with a variety of cal kit parts and this is handy to have.
The Spectrum Analyzer (timed demo) is what they say it is and LESS.  Siglent calls it basic spectrum analysis.  A big surprise is that it is not a swept superhet type of SA.  They use various mixing / multi level suppression methods which I can just grasp.
The SA lacks MANY of what we've come used to seeing on an analyzer.  You can't even change input attenuation in, say, 10dB steps.  It only has a "standard", "low noise" and "auto" setting.  What it is providing is not published and I didn't have time to test it.  The SA lacks most additional functions found in a $1600 SSA3021X-P.  The input has NO correction capabilities, another disappointment.  Not to remain on this downhill slope, I'll stop.
But the VNA shines and I love it.  The SA should be FREE in its current form.  The Time Domain math (also timed demo) looks very good.
For a handful of minutes I was in fear of not being able to display a stored trace and a live on top of it.  Siglent does not make this easy.  But their trace COPY, MOVE and other stuff seems pretty complete.  I was able to get a live and stored overlayed but need to do it a few more times.  I think this would make a good YouTube video as it's commonly used.  Maybe when I get some free time.  update - displaying live and stored trace is a piece of cake which I missed.  It's under MATH.
So in summary, after two days of major playing, the VNA gets 10 chili peppers while the SA gets a 0.5 chili pepper.
« Last Edit: May 18, 2024, 01:26:12 pm by EE-digger »
The following users thanked this post: egonotto, Martin72
« Reply #78 on: May 12, 2024, 03:05:27 am »
Screenshots of interesting stuff or it's all lies Dennis.  :P
Offline EE-digger
« Reply #79 on: May 18, 2024, 09:37:39 pm »
Here is a selection of screen shots from the SNA5002A.  I only included one SA image but in answer to those wondering about the low end, it looks good down to 9kHz.
The S11 noise floor seems to vary with IFBW (not always better when lower) and the number of points helps.  I like to run 1601 points out of old habit.
Some of the shots show the hard keys on and off.  Siglent was genius to include the hard keys on the remote interface.  You don't NEED to have them on because you can go back from the column of soft keys, with a lot more button pushing.
All I can say is that I'm very happy with the VNA. The SA is in a different league and that's all I'll say on this glorious day  :-+
< OPEN EACH IMAGE IN A NEW TAB FOR FULL RESOLUTION >
« Last Edit: May 18, 2024, 09:49:01 pm by EE-digger »
The following users thanked this post: rf-loop, Performa01, egonotto, tautech, 2N3055
Offline fjullien
« Reply #80 on: May 27, 2024, 09:36:18 am »
Hi EE-digger,
Could you please detail how you got this working?
I'm still looking for this after several minutes :)
Franck.
Offline fjullien
« Reply #81 on: May 27, 2024, 09:44:27 am »
Ok, I think I've found it. The "Data->Memory" button copies the trace to the memory of this one trace.
Then, "Display" let you choose if you want to display the trace or trace+memory or the memory alone.
Offline EE-digger
« Reply #82 on: May 28, 2024, 04:09:24 pm »
Glad you found it.  There are other things which could use written help somewhere.
Averaging is another.  In VNA, you enable averaging under the IFBW button.  In SA, like many SAs, you change the trace type (under math, trace type) to averaging.  Averaging then appears on the soft keys.
I'm also in search mode, see next post.
Offline EE-digger
« Reply #83 on: May 28, 2024, 04:11:25 pm »
The SNA5000A does not have a ZERO SPAN mode for the SA.  This is a real problem because without it, you can't examine any time domain characteristics of a single frequency signal (for instance, advertising on Bluetooth).
I hope Siglent will add this at some point.  I hope they can.
Offline EE-digger
« Reply #84 on: July 16, 2024, 03:02:50 pm »
In VNA mode, does anyone know if there's a way to use a delta marker between a memory trace and the current data?  The memory trace does have it's own markers, using the same marker numbers but in their own little world.
Offline gordoncs
« Reply #85 on: August 03, 2024, 02:57:48 am »
BW45 - BandWidth-4.5G
BW85 - BandWidth-8.5G
Many thanks to TV84 for the BW information.
And is this correct? BW135 - 13.5G BW265 - 26.5G
« Reply #86 on: August 03, 2024, 03:07:06 am »
Only for the later models that support these frequencies.
https://int.siglent.com/products-overview/sna5000a/
Frequency range: 9 kHz ~ 8.5 GHz and 100 kHz - 26.5 GHz
The following users thanked this post: gordoncs
Offline gordoncs
« Reply #87 on: August 03, 2024, 03:16:34 am »
Thanks to tautech
I'll buy a SA5022A, and want to 26.5
« Reply #88 on: August 03, 2024, 01:53:37 pm »
Thanks to tautech
Keep us posted.  :popcorn:
One other point about the high BW models, they are only currently available as 2 port models and have NMD 3.5 mm port terminals......but these 4 port monsters might be coming......as the switch matrix is already available.
https://siglentna.com/rf-switch-systems/ssm5000a-switch-matrix/
« Reply #89 on: August 19, 2024, 08:24:45 am »
Thanks to tautech
We played (well hendorog mainly) with one of these 20kg 26.5 GHz beasts at HQ last week and lucky we were travelling light or it woulda ended up in hendorog's luggage.  :-DD
We'll have more news on SNA6000A western release soon......
« Reply #90 on: August 22, 2024, 08:10:32 am »
New firmware for SNA5000A models
Version: V1.0.0.2.12
73 MB
4.5-8.5 GHz models
https://int.siglent.com/upload_file/zip/firmware/Vector%20Network%20Analyzer/SNA5000_V1.0.0.2.12_EN.zip
13.5-26.5 GHz models
https://int.siglent.com/upload_file/zip/firmware/Vector%20Network%20Analyzer/SNA5022A&SNA5032A_V1.0.0.2.12.zip
Release notes
1. Add material measurement function option
2. Add switch matrix expansion multi-port application options
Offline tv84
  • Country: pt
« Reply #91 on: September 03, 2024, 10:04:18 pm »
Current options with V1.0.0.2.12.
« Reply #92 on: September 03, 2024, 10:14:46 pm »
WRT the attachment, there is no such western model as SNA5054X.
Best 4 port VNA currently available is SNA5014A.  ;)
Offline tv84
  • Country: pt
« Reply #93 on: September 03, 2024, 10:32:34 pm »
No geographic war intended... I played with a eastern toy.
As you know, SNA5054X = SNA5004A and with RFE8 becomes a SNA5084X (SNA5014A).
Edit: Added an "A model" to make tautech happy. :)
« Last Edit: September 06, 2024, 02:55:06 pm by tv84 »
« Reply #94 on: September 04, 2024, 09:47:37 pm »
Done ?
 :popcorn:
