Hi everyone,
I read some stuff on this forum about ATTEN 1102CAL oscilloscope. I know original firmware may have problem but it's not mine and I can't update the firmware.
for instance here :
https://www.eevblog.com/forum/reviews/atten-ads1102cal-trigger-uncertaintyjitter-problem/but it is very specific whereas i'm looking for doing something really evident.
I juste wanted to check because I would like to know if I'm facing a firmware bug problem or if I don't know how to use the oscilloscope.
In fact, I don't succeed to make the trigger working in "single" mode.
I want to display the rise of power up on a signal that will rise from 0v to 12V. I can display it at 0v, then I power up my circuit and I can see the signal at 12V.
I configured the trigger in single mode and I wanted the oscilloscope to trig when the voltage rise a bit. for instance I set the trigger at 1V. but in single mode, the trigger never trig...
do I miss something important ?
