Thank you very much!
I hope Siglent will help me ![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
As your HH is branded as AKIP, you should contact them too about your problem.
Your local brand distributor should always be your first contact.
Do understand AKIP have this unit with their name on it, so it is their responsibility to support it in the first instance, not Siglent's.
I can't say if it's a bug, it might be.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Last Siglent FW was in March, so I'd guess the next FW 6 months from then.
So looking forward, you should keep an eye out for new FW updates for the next few months.
But you have found a solution in the method you store and recall, hopefully that's a good work around untill new FW is released.
