Certainly Rigol is an excellent buy for 3-digit dollars. If you're just getting started with electronics, the DS1054Z is a great place to start. Unless you already have quite a lot of experience using oscilloscopes, in the long run you'll probably save much more than $400 by learning first on a DS1054Z. It's also quite capable, so odds are also good you won't feel much need to buy anything better for quite a long time. By then, better products will exist.
But if you are going to spend more now, I'd also recommend looking at Keysight (formerly Agilent) if you're looking going to spend much more than those low-end Rigol scopes. I have an Agilent on my desk, and I've used the Rigol scopes several times. I'd say the Agilent is about 2X, maybe 3X nicer, for about 10X the price.
The trouble with online spec lists is they lack the truly important things, like how responsive the user interface is (especially as more features are turned on), how free of bugs and poor design the firmware is, whether the front panel is easy to learn and use, and whether the rapid capture rate and intensity grading actually helps you to notice some infrequent behavior. Many products exist with impressive spec lists, which are intended to sway inexperienced buyers and non-technical people like managers and purchasing agents who are often the people that make the purchase decisions in corporate settings.
