New firmware for SHA800A models.
Version: V2.1.2.1.6R5
67 MB
https://int.siglent.com/upload_file/zip/firmware/Spectrum_analyzer/SHA850A_V2.1.2.1.6R5_EN.zipRelease notes
New Features:
•Kml recording function.
•Supports importing maps.
•Supports map feature under Channel Power measurement record playback in SA mode.
SCPI Commands:
•Added [ [:SENSe]:WAVeform:POINts? ] command to obtain the number of IQ sampling points.
•Added [ :FETCh:WAVeform? ] command to obtain IQ collected waveform data.
Optimized Function:
•Optimized the Channel Power measurement refresh response efficiency in SA mode.
•Optimized VNC refresh efficiency.
Solved Problem:
•Fixed unstable frequency counter in SA mode.
•Fixed audio demodulation buzzing sound in SA mode.
•Fixed when trace is view in SA mode, a large error will be obtained when executing alignment.
•Fixed incorrect sequence number when harmonics obtain fundamental wave amplitude in SA mode.
