Author Topic: Siglent SHA800A  (Read 11793 times)
Offline oeweanTopic starter
  • Country: no
    • Adroit.no
Siglent SHA800A
« on: November 08, 2022, 10:20:51 am »
Hi!
On the Chinese Siglent website there is a new product:
Siglent SHA800A, a Portable  spectrum analyser with a frequency range up to 7,5GHz
https://www.siglent.com/products-overview/sha800a/
Datasheet attached
Looks promising :-)
« Last Edit: November 08, 2022, 10:27:09 am by oewean »
Norwegian distributor of test and measurement equipment....
Adroit.no
Offline tautech
Re: Siglent SHA800A
« Reply #1 on: November 09, 2022, 07:29:13 am »
Good find.  :)
Portable SA/VNA with 8.4" touch display and 4hr battery life.
VNA capability S11 and S21 measurements, reflection/transmission coefficient, return/insertion loss, phase, group delay, standing wave ratio, Smith chart, polar chart etc.
Optional accessories include
GPS antenna
Directional antennas
A customer sent us a translation of the datasheet.
Link to latest datasheet:
https://int.siglent.com/u_file/download/23_08_28/SHA850A_DataSheet.pdf
« Last Edit: September 05, 2023, 12:43:27 am by tautech »
Offline tautech
The following users thanked this post: egonotto, 2N3055, aduinstat
Offline tautech
Re: Siglent SHA800A
« Reply #3 on: September 01, 2023, 04:00:16 am »
Learning its capabilities ..... somewhat more than the SVA1000X models......
GPS and MAP tile files are new to me and used to record coordinates of remote transmission/repeater stations.
VNA sweep of SWR and Log Mag from a 200mm 2.4 GHz WiFi SMA antenna displaying further resonant frequencies.
Seems GPS has no problem finding satellites even when inside under a tin roof.  :o
Outside I've had 17 show up which of course much improves altitude accuracy.
Offline lty1993
    • LTY's Space
Re: Siglent SHA800A
« Reply #4 on: September 04, 2023, 08:03:15 am »
I received mine today. The firmware version is 1.1.2.1.6R0. It seems that the firmware and the user manual still require some refinement.
Offline tautech
Re: Siglent SHA800A
« Reply #5 on: September 04, 2023, 08:52:40 am »
Nice.  :)
Had mine a couple weeks and it arrived with the now online FW, V1.1.2.1.5R0 for which I now have a beta version a little later than yours.
However the Option page Trial times weren't displayed correctly (no 120hrs Trial mode) and I got a special file from HQ to remedy it.
Yes the manual is under further development and I have a section on MAP that is not added to the public manual yet.
What do you need help with ?
Offline lty1993
    • LTY's Space
Re: Siglent SHA800A
« Reply #6 on: September 04, 2023, 01:56:40 pm »
I can confirm that my unit was shipped without any trial license installed. It only has the F1 and CAT permanent licenses installed by default, as it is the base model.
I can see on siglentna.com that GPS and GPSM are out of stock. It is possible that they are not finished functions and are not available for purchase by the public.
I don't currently require assistance with anything. Everything is going well so far. I simply want to share my experience.
Offline tautech
Re: Siglent SHA800A
« Reply #7 on: September 04, 2023, 11:33:51 pm »
Yes spotted that too however it's outdated as I purchased GPS and GPSM.
The GPSM option has been renamed as MAP in the instrument although still is listed as GPSM in pricelists and on websites to better align with UI menus.
https://int.siglent.com/article/detail-952.html
With the beta FW and license patch the screenshot below is what the Options page should look like with Trial options displayed and the MAP option is below the bottom of the page.
Offline lty1993
    • LTY's Space
Re: Siglent SHA800A
« Reply #8 on: September 05, 2023, 04:46:29 am »
LOL, if you're going to patch a license, why not make it permanent? Actually, you can extract the license code from the running program while adding an incorrect license to it.
Offline tv84
  • Country: pt
Re: Siglent SHA800A
« Reply #9 on: September 05, 2023, 09:47:57 am »
Sure you can (at least for now...) and what about the F1, did you tried it?
Offline lty1993
    • LTY's Space
Re: Siglent SHA800A
« Reply #10 on: September 05, 2023, 02:48:53 pm »
Installing F2 will automatically remove F1. They are bandwidth license.
Offline tautech
Re: Siglent SHA800A
« Reply #11 on: September 05, 2023, 10:49:10 pm »
You misunderstood, the patch was supplied by Siglent for the Trial time periods to be displayed like in all other Siglent analyzers.
Study my screenshot above where all temporary option licenses display the trial time remaining.
Offline tautech
Re: Siglent SHA800A
« Reply #12 on: September 09, 2023, 04:20:29 am »
Getting to know this more to see what the trace colors are for the 6 traces it can do.  :o
3 GHz @ 0dB from cough  ;) SSG3021X via RG214 with 10 Hz RBW and missing a couple steps to 300kHz RBW.
All traces Peak Hold however with the long sweep times for low RBW settings I haven't allowed for multiple sweeps to display less noise.
Offline tautech
Re: Siglent SHA800A
« Reply #13 on: September 26, 2023, 09:11:28 am »
New ECal units just released.
SEM5000A range.
4.5, 9, 13.5 and 26.5 GHz, 2 and 4 port N type, SMA and 3.5mm variants.
https://int.siglent.com/u_file/images/23_09_25/SEM5000A_datasheet_DS60050_E01A.pdf
SEM5000A series electronic calibrators include 5002A / 5012A / 5022A / 5032A / 5004A / 5014A / 5024A / 5034A, covering the frequency bands of 9kHz to 4.5GHz / 9kHz to 9GHz / 100kHz to 13.5GHz / 100kHz to 26.5GHz, with USB interface for communication and power supply, and the RF connectors come in three forms: SMA, 3.5mm, and Type-N. They are suitable for calibration and error correction of SHA850A series, SVA1000X series and SNA5000A series vector network analyzers of SIGLENT. The SEM5000A series are simple, fast, efficient, accurate, and widely applicable.
Prices from $2,345
« Last Edit: September 26, 2023, 09:04:04 pm by tautech »
Offline tautech
Re: Siglent SHA800A
« Reply #14 on: January 31, 2024, 02:58:31 am »
New firmware for SHA800A models.
Version: V2.1.2.1.6R5
67 MB
https://int.siglent.com/upload_file/zip/firmware/Spectrum_analyzer/SHA850A_V2.1.2.1.6R5_EN.zip
Release notes
New Features:
•Kml recording function.
•Supports importing maps.
•Supports map feature under Channel Power measurement record playback in SA mode.
SCPI Commands:
•Added [ [:SENSe]:WAVeform:POINts? ] command to obtain the number of IQ sampling points.
•Added [ :FETCh:WAVeform? ] command to obtain IQ collected waveform data.
Optimized Function:
•Optimized the Channel Power measurement refresh response efficiency in SA mode.
•Optimized VNC refresh efficiency.
Solved Problem:
•Fixed unstable frequency counter in SA mode.
•Fixed audio demodulation buzzing sound in SA mode.
•Fixed when trace is view in SA mode, a large error will be obtained when executing alignment.
•Fixed incorrect sequence number when harmonics obtain fundamental wave amplitude in SA mode.
Offline tautech
Re: Siglent SHA800A
« Reply #15 on: January 31, 2024, 04:02:28 am »
2 further model series in these portable analyzers are coming:
SHA860A RTSA models to 7.5 GHz
https://www.siglent.com/products-overview/sha860a_n/
SNA900A 14, 20 and 26.5 GHz models.
https://www.siglent.com/products-overview/shn900a/
Unknown pricing and release dates at this time.
Offline tautech
Re: Siglent SHA800A
« Reply #16 on: April 09, 2024, 02:30:49 am »
Version: V2.1.2.1.7R2
64 MB
https://int.siglent.com/upload_file/zip/firmware/Spectrum_analyzer/SHA850A_V2.1.2.1.7R2_EN.zip
Release notes
New Functionality:
Add GNSS timing.
Add the outdoor map downloader software EasyMAP.
Add automatic screenshot and data store for LIMIT.
Improvements:
UI Response improvement
Solved Issues:
Fixed small RBW display.
Fixed the abnormality of warm drifting calibration (compatible with old machines: calculating two problems with errors).
When the DTF is solved to the feet format, the cursor returning unit is the problem of YARDS.
Offline tautech
Re: Siglent SHA800A
« Reply #17 on: April 11, 2024, 10:14:38 am »
Siglent kindly sent me a download link to their beta SW to assess and use.
It allows for PC download of various map types of which I selected Google Street maps for initial tests and navigated and zoomed to Auckland NZ to download and install the GPS PNG files into the Map cache.
No documentation was provided however if a dummy like me can use it successfully when the formal instructions for when it goes live should provide simple usage guidance.
With the GPS functionality ON and GPS Locate engaged it found me in an instant.
Attached is screenshot proof.  :P
Offline tautech
Re: Siglent SHA800A
« Reply #18 on: April 11, 2024, 05:22:33 pm »
Info that is not in SHA800A documentation:
Maps saved inside the SHA850A up to 3.2GBytes.
