Author Topic: Hacking the Rigol DHO800/900 Scope  (Read 1629978 times)
Offline FxDev
  • Country: tr
Re: Hacking the Rigol DHO800/900 Scope
« Reply #2850 on: August 13, 2024, 10:33:31 pm »
I tried DHO804 with 30.000mAh battery bank.
It worked around 2.5 hours. FYI.
The following users thanked this post: Pinkus, egonotto, Fungus, AndyBig, RAPo, RogerG, norbert.kiszka
Offline RogerG
« Reply #2851 on: August 14, 2024, 11:21:45 am »
Just bored, or were you waiting for anything specific?  ::)
Waiting for new FW or another interesting hack  :popcorn:.
Offline norbert.kiszka
« Reply #2852 on: August 14, 2024, 11:29:02 am »
Do Your own one and share it with us.
Offline ebastler
« Reply #2853 on: August 14, 2024, 02:43:40 pm »
... or consider actually using the scope to measure something interesting.  :P
The following users thanked this post: RAPo
Offline Lathe26
« Reply #2854 on: Today at 04:27:16 pm »
Exporting waveform (to a file) from internal memory doesn't work and I have no idea why. According to DHO800-Series_programmingguide_EN.pdf it should work. Command :WAV:DATA? return is: "The instruction is not supported!". Please let me know, if somebody knows how to do it.
I've seen ":WAV:DATA?" work but only for the analog channels.  It doesn't work properly for LA channels (D0, D1, etc) due to bugs causing an earlier ":WAVeform:SOURce D0" to fail.
Attached is a Python file from Rigol that I think I haven't changed too much.  This should still be in its original working form, but not guaranteed.
