Make some movie.... ![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
you dont have to ask, that is his main job... we'll be waiting for it. i hope cover all the functionalities... including FFT plot shown here (if possible downloading data to PC) ymmv.
(Attachment Link)
Purchased wall wart linear regulated.
how can cheap wall wart linear regulated be this good? -80dB is like 100uVpp noise?
First just one note. Do you know how much is -80dB... for hint. Just today in food store milk price was -50%
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
But yes I can in this case guess that you mean dBV(rms) what is 0.1mVrms.
I'm too busy (and lazy) to start basic lectures about levels (in time domain and FFT). But I'll put one picture here, the content of which might be good and useful to think about.
(because now you know input signal and it is not "unknown walmart"
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
![](https://www.eevblog.com/forum/testgear/siglent-sds800x-hd-12-bit-dsos-coming/?action=dlattach;attach=2106038;image)
In this picture there is two channels on.
Ch3 no signal (only 50 ohm termination) 5mV/div, full 200MHz BW
Ch4 input random noise 2mV Stdev from generator (and 50 ohm feed thru termination in scope input) Channel set for 5mV/div, full 200MHz BW
Only difference is that for visibility reasons I have adjusted time domain signals vertical position
FFT both have all same settings, range 250Hz to 25MHz, window FlatTop, trace average 1024 (and even if no average at all, FFT (F4) peak level is roughly about -100dBV in this case. Vertical axis also same.
F1 FFT Ch3 as base noise reference, all settings same as F2
F4 FFT Ch4 Start 250Hz and stop 25MHz
Time domain easurements: Ch4 V Pk-Pk and Stdev. As can see signal is near 2mV AC rms (Stdev) and peak value about 18mV
And there can see Ch4 FFT(4) trace level between -105dBVrms and -110dBVrms
