I had to play around a bit earlier...
Bodnar connected over 50Ohm, risetime measured.
And then I noticed something in the menu, I could have sworn I hadn't seen it before with the 2000Xplus or HD.
At the bottom of the Measure menu there is an item "Result Style", where you can choose between Embedded or Floating - I think the result is very good.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
Perhaps this point was added because of the smaller screen.
Somewhat funny:
The default button, no longer embedded in the front...
Thank goodness there is a prompt asking whether you want to reset or not.
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
If you go back to the defaults, however, not everything is reset to the factory settings.
So jpg is set back to png, time and date are also set back - but time zone and LAN settings are not.
Martin
