I had to play around a bit earlier...
Bodnar connected over 50Ohm, risetime measured.
And then I noticed something in the menu, I could have sworn I hadn't seen it before with the 2000Xplus or HD.
At the bottom of the Measure menu there is an item "Result Style", where you can choose between Embedded or Floating - I think the result is very good.
Perhaps this point was added because of the smaller screen.
Somewhat funny:
The default button, no longer embedded in the front...
Thank goodness there is a prompt asking whether you want to reset or not.
If you go back to the defaults, however, not everything is reset to the factory settings.
So jpg is set back to png, time and date are also set back - but time zone and LAN settings are not.
Martin
