Author Topic: Siglent SDS800X HD 12 bit DSO's  (Read 849098 times)
Offline ptluis
  • Country: pt
Re: Siglent SDS800X HD 12 bit DSO's coming
« Reply #400 on: February 20, 2024, 05:35:18 pm »
Anyway it's possible to use a bench scope with DC power, I do that with a 54V battery pack connected to AC input of SDS1202X-E or SDS1204X-E
Nice, then expect the same form factor SDS800X HD to work with a battery pack also as it likely uses the exact same PSU as the 4ch X-E models.....maybe that's something Defpom can confirm.
54V into PSU is forcing input circuits to work with much higher currents than normal... It is operating outside PSU operating parameters...
Do at your own risk...
I never had a problem fedding 54V DC into the scopes AC power supply, SDS1104X-E, SDS1202X-E, GWINSTEK, TEKTRONIX, also on TV's, PC computers, Laptops and other devices, etc. Never burn one. For ex: SDS1104X-E work about 5-6h daily for the past 4 years, never had a single problem.
The following users thanked this post: orzel
Online Martin72
  • Testfield Technician
« Reply #401 on: February 20, 2024, 06:47:06 pm »
This is not proof of safe operation just because nothing has happened so far.
You've just been lucky. ;)
(Kierkegaard)
Offline ptluis
  • Country: pt
« Reply #402 on: February 20, 2024, 07:15:13 pm »
it's something I've been doing for 40 years. this means two things, 1st I'm in fact lucky for not blowing devices, 2nd smps are strong enough to support this kind of abuses  :-DD
Online Martin72
« Reply #403 on: February 20, 2024, 11:10:19 pm »
With 54 volts you are operating the device outside its specification, that is a fact that cannot be refuted.
And "it has worked like this for umpteen years" is not an argument in its favor.
It's just the way it is.
(Kierkegaard)
The following users thanked this post: rf-loop
Offline lunix
« Reply #404 on: February 21, 2024, 12:35:15 am »
40 years- when most power supplies were still linear?  Not believable.  Why 54 volts?  Not 55, not 50.  Also suspicious.
Offline ptluis
  • Country: pt
« Reply #405 on: February 21, 2024, 09:46:03 am »
40 years ago smps do exists, nothing suspicious about it. Computer smps for example. IBM XT PC, I know because I worked at IBM back in those days, and repaired many units, along with mainboards, not like today where we just replace parts... Comodore Amiga are also an example of using smps, the 500 model uses an external smps, this model come out maybe 3-4 years after IBM if I recall correctly. So smps do exist back then, not so common as today's days.
concerning 54V, it depends on smps design some start to operate at around 44v some a little less, but for stability a little higher voltage is required. Of course everyone is responsible for their actions, meaning if you decide to try it and burn the device don't blame me. I do it anytime for many years with zero failures. even with those cheap chinese dvd players with shitty PS. And although for most of you operating a scope with DC power is not a concern, every manufacturer should consider this feature, because we live in a time where portable devices are a must these days and there's not much offer in this class of equipments .
And btw, for those amateurs who will find this amazing, beware that dealing with 54V DC could kill you or burn you.
« Last Edit: February 21, 2024, 09:52:07 am by ptluis »
The following users thanked this post: Mortymore
Online TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #406 on: February 21, 2024, 10:35:17 am »
Well,
Looking in the datsheet of the 1000X-E, there´s no word about bandwith upgrade but we all know it is possible.
Was just going to mention that.
Rob or Defpom are just going to have to give it a go!!!
Inquiring minds need to know!!!!
I gave Rob his scope back today, so he will be able to answer this soon (he has already told me the outcome, but I will let him tell you)
Cheers Scott
Online tautechTopic starter
« Reply #407 on: February 21, 2024, 10:58:31 am »
Well,
From in early life, Hogans Heros, Sgt Shultz: I know nothing, see nothing, hear nothing....  :-X  ;)
The following users thanked this post: Bad_Driver, hallkbrdz
Offline orzel
    • Sylphide Consulting
« Reply #408 on: February 21, 2024, 04:39:15 pm »
We have higher-resolution teardown photos of the SDS1000X HD now, and it does come with DDR RAM chips of twice the capacity compared to the 814X HD. (In an otherwise similar layout.) So that RAM is probably needed to support the 100 MPts memory, and I would expect to find the larger RAM chips in the 824X HD as well. Doesn't look good for upgradability.  :(
Doesn't look good for the memory upgradability, but just having the better frontend bandwidth is already a lot.
« Reply #409 on: February 21, 2024, 08:58:48 pm »
Hello,
Is it possible to measure the mains frequency by setting the trigger to line and activating the counter? I can't do it with the Rigol DHO1074.
Best regards
egonotto
Yes, confirmed with SDS800X HD also.
Screenshot captured via webserver.
« Reply #410 on: February 21, 2024, 09:18:37 pm »
Something very weird happened to my SDS814X HD BW.....
But it was easy to fix.  :phew:
« Last Edit: February 22, 2024, 01:40:41 pm by tautech »
The following users thanked this post: Mortymore, BillyO, Martin72, mwb1100, orzel, sebyon
Offline orzel
« Reply #411 on: February 21, 2024, 09:47:21 pm »
Something very weird happened to my SDS814X HD.....
Yeah !!  :-+ :clap:
Thanks a lot for checking and reporting.
Online Martin72
« Reply #412 on: February 21, 2024, 10:24:49 pm »
Did you pay attention to how many memory points were available before the "correction"? 8)
(Kierkegaard)
The following users thanked this post: mwb1100
Offline BillyO
« Reply #413 on: February 21, 2024, 11:02:04 pm »
Did you happen to accidently do any BW measurements before you fixed it? :-DD
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
« Reply #414 on: February 21, 2024, 11:13:12 pm »
:scared:
Do I really need to tell you how to read the settings in a Siglent DSO screenshot ?  ::)
The following users thanked this post: Martin72, core
Online Martin72
« Reply #415 on: February 21, 2024, 11:21:02 pm »
Oopsie...Now you mentioned it.... ;D
Excellent.
(Kierkegaard)
Offline BillyO
« Reply #416 on: February 22, 2024, 12:30:34 am »
Now I just have to decide between this and the 1000X HD.  This will physically fit better where it has to go (needs to go where my SDS1000X-E is now) and costs less. :-// :popcorn:
« Reply #417 on: February 22, 2024, 01:55:27 am »
Some height restriction ?
SDS1000X HD is just 5mm wider than SDS1004X-E/SDS800X HD.
SDS1000X HD Length × Height × Width = 317.2 mm × 236.0 mm × 149.0 mm
SDS800X HD Length × Height × Width = 312 mm × 151 mm × 132.6 mm
Patience friend, in due course these measurements will be made.
Already we know SDS814X HD =~155 MHz and I suspect the 70 MHz SDS804X HD might even challenge the ~120 MHz of SDS1104X-E but these test take time and life is busy....
Offline RFDx
« Reply #418 on: February 22, 2024, 03:58:04 am »
Hello,
Best regards
egonotto
f=50.00000Hz? Doesn't look like the mains frequency is really being measured. Same with the SDS1000HD.
Offline BillyO
« Reply #419 on: February 22, 2024, 04:06:15 am »
Sometimes it is exactly that.  Look up a mathematical theorem called the "mean value theorem".  If you know any mathematics, this will help you understand.
Offline RFDx
« Reply #420 on: February 22, 2024, 05:02:58 am »
Are you trying to insult my math skills :P? Having the "luck" to measure precisely 50.00000Hz with 10µHz resolution afterall at two different days and times? Maybe, but (for now) very very unlikely.
Offline BillyO
« Reply #421 on: February 22, 2024, 05:12:32 am »
No, just trying to be funny. :-DD
Offline Rudgas
« Reply #422 on: February 22, 2024, 09:20:11 am »
Crystal ball says the 804X HD will go for around 409€ in GER incl. VAT. Very competitive indeed. Now to see where the 1000XHD will land and if the increased features will convince me to spend more for capability I don't really need  ;)
Offline tszaboo
« Reply #423 on: February 22, 2024, 09:24:00 am »
I don't think they bring that model to Europe.
« Reply #424 on: February 22, 2024, 09:39:20 am »
IMO 50/60Hz Line frequency indication is just a nominal value from line frequency autodetect and I agree the measurement to 5 LSD is quite unnecessary.
2 screenshots from an AC wallwart as an example.
The following users thanked this post: RFDx
