Author Topic: Siglent SDS800X HD 12 bit DSO's  (Read 861926 times)
0 Members and 12 Guests are viewing this topic.
Offline Antonio90
Re: Siglent SDS800X HD 12 bit DSO's coming
« Reply #200 on: December 16, 2023, 05:30:45 pm »
I don't think Android has any inherent advantage over regular Linux for a bench scope. Other than initial ease of development and abundance of developpers for the platform.
Once you have an estabilished platform and software crew, the advantages stop.
Linux isn't known for it's UI toolkits.
The chipset inside the Rigols is designed around Android. An Android system will be far more integrated/robust than somebody trying to cobble together a Linux system.
Well, I don't know much about development, but there are many TE based on Linux without any stability or robustness problems, Keysight for example.
Offline blurpy
  • Country: no
« Reply #201 on: December 16, 2023, 05:52:45 pm »
Siglent uses Qt, which is a pretty powerful framework, predating anything Android by more than a decade, and constantly evolving.
It's used by KDE, which happens to be my favorite desktop environment.
I hope Siglent stays with pure Linux, and spend the extra processing power on useful measurements instead of bling and cheaper junior devs.
The following users thanked this post: egonotto, Mortymore
Offline Martin72
  • Testfield Technician
« Reply #202 on: December 16, 2023, 06:03:05 pm »
I mention is because the Rigols have massively more bandwidth than advertised, not just "a bit".
This is not necessarily an advantage; depending on the sample rate, a higher bandwidth can be counterproductive.
For example, with 312.5MSa/s and 200Mhz bandwidth.
(Kierkegaard)
The following users thanked this post: egonotto, 2N3055
Online KungFuJosh
  • TEAS is real.
« Reply #203 on: December 16, 2023, 06:03:27 pm »
Qt is an excellent platform, with a lot of power for UI design. QSS works very similar to CSS, and can be used for extensive UI/UX control. Anybody claiming that Android is a better environment doesn't know what they're talking about. Also, I've seen what Rigol has done with the UI potential, and it looks like every element of their design is dated by at least 15 years.
I didn't know Siglent was using Qt, but now I'm curious if any of the QSS files are accessible, or if it's all hard coded in. 🦹
Offline blurpy
  • Country: no
« Reply #204 on: December 16, 2023, 06:20:09 pm »
I haven't found anything on the file system or in the firmware updates. Looks like they bundle the Qt framework in the OS, and a single executable for the app.
Online KungFuJosh
  • TEAS is real.
« Reply #205 on: December 16, 2023, 06:21:08 pm »
Boo. It would be so cool if they had some editable QSS files on there. Then we could customize the shit out of it.
Offline 2N3055
  • Country: hr
« Reply #206 on: December 16, 2023, 07:32:19 pm »
It is irrelevant what OS is manufacturer using. It is what it is.
Maybe 90% of scope development is NOT UI work.
Math, measurements, FPGA, etc. takes most of the work.
Scopes are not computer games...
That being said, can we please keep on topic this time?
The following users thanked this post: Performa01, egonotto, Warhawk, KungFuJosh, Martin72, techneut, PELL
Offline tv84
  • Country: pt
« Reply #207 on: December 16, 2023, 09:40:25 pm »
You're definitely known for becoming an instant guru on a device just by smelling its fumes but that doesn't mean you known all the stuff. What the heck makes you say something like this?
The following users thanked this post: ddrl46, Performa01, egonotto, Warhawk, hansibull, Muxr, Mortymore, wolfy007, KungFuJosh, Martin72
Offline Fungus
« Reply #208 on: December 17, 2023, 02:44:07 am »
Giving Fungus the benefit of doubt, I assume he meant the SoC when he said "chipset"
Yep. What else would I mean?
If however "chipset" refers to the data acquisition engine, I agree that it seems absurd to assume that this was "designed around Android".
Absurd would be assuming I meant that.
Some people around here need to learn about Occams razor. It makes life much simpler.
Offline Performa01
  • Country: at
« Reply #209 on: December 17, 2023, 09:49:57 am »
Some people should learn to use the right terminology to say what they actually mean. That would make life simpler.
Alright! On the other hand, isn’t it totally meaningless what incompetent persons actually mean?
Offline mouz
  • Country: pt
« Reply #210 on: December 17, 2023, 11:38:25 am »
I just noticed this because the Batterfly video popped up.
Obviously will be directly compared with the Rigol 800/900
So far I see no VESA mount and no HDMI, two of the big additions to the Rigol 800/900. You could also add in USB-C power and the slim form factor, but that's always arguable.
Is the Rigol DHO800/900 Series the only scope with VESA mount in this price range ?
if you squint it's mint
Offline Fungus
« Reply #211 on: December 17, 2023, 12:20:11 pm »
Yes.
The following users thanked this post: mouz
Offline TobeAGoodOne
  • Country: cn
« Reply #212 on: December 30, 2023, 06:17:27 am »
Just try this in the keygen python code :
Model = 'SDS800X-HD'
The following users thanked this post: PELL
Offline Silver_Is_Money
« Reply #213 on: December 31, 2023, 03:35:44 pm »
Is there a North American release date for the Siglent SDS800X series yet?
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #214 on: December 31, 2023, 06:23:54 pm »
[Insert obligatory "it will be ready when it's ready", "Siglent is all about quality, not driven by release schedules" etc. sermon here.
are you saying there will be no fw bug when its out? are you willing to bet? ;)
Offline 2N3055
  • Country: hr
« Reply #215 on: December 31, 2023, 07:08:42 pm »
There won't be Rigol style clusterf**k for sure.
There will be bugs of course, everything has bugs. But it will actually work.
Just a hint: it won't try to sample 250MHz signal with 156 Msps/s ....
  • Country: my
« Reply #216 on: December 31, 2023, 07:42:42 pm »
you keep spitting that bullshit. not with the 70MHz model. and at least they have LA port... sorry if you got easily insulted siglent fanboy ;D
Offline 2N3055
  • Country: hr
« Reply #217 on: December 31, 2023, 07:43:59 pm »
Omg, the rage, you keep posting several times...
Added to ignore list, troll...
  • Country: my
« Reply #218 on: December 31, 2023, 07:48:07 pm »
now its fair, you've been in the list since the beginning fyi, i found its fun to keep clicking "show post".. almost always reveals wonder. now you dont have to reply to me and i dont need you to.. good grieve ;D
Offline Fungus
« Reply #219 on: December 31, 2023, 08:59:53 pm »
You're going to be talking to yourself, soon.
Offline Fungus
« Reply #220 on: December 31, 2023, 09:02:07 pm »
Please tell us what the sample rate of these will be with four analog channels and the logic analyzer,,,
Online KungFuJosh
  • TEAS is real.
« Reply #221 on: December 31, 2023, 09:54:49 pm »
Can't have a Siglent thread without angry Rigol fanboys having temper tantrums and trolling. 🙄
The following users thanked this post: ddrl46, Performa01, wolfy007
  • Country: my
« Reply #222 on: January 01, 2024, 09:36:59 am »
you mean like this? ;D https://www.eevblog.com/forum/testgear/rigol-dho800900-oscilloscope-bug-reports-firmware/msg5252421/#msg5252421 admittedly we have rigol fanboy going around...
i'm not sure whether they have their mom or family work in high ranking siglent office, but i'm not sure why they got easily insulted. and its funny why some people have to swear by its "quality" we know its proportionally to the price. lets wait how SDS800X goes. i only believe demand and supply rule nothing more. if you have good price and quality, whether you tantrum or not, lot of people are going to buy it... rigol may not have good after sale service but... like dom said... "winning is winning" whether you tantrum or not, who got threatened? "their" family? oh please!
Offline Fungus
« Reply #223 on: January 01, 2024, 12:20:13 pm »
Go and look who was the first "subscriber" in the Project Raigol thread, and reposted it endlessly, along with that stupid "Rigol vs. Siglent" comparison spreadsheet.
The following users thanked this post: Mechatrommer
Online KungFuJosh
  • TEAS is real.
« Reply #224 on: January 01, 2024, 04:14:26 pm »
Ah, there we go. "The Rule of Two." 🤣
