Author Topic: Siglent SDS7000A 3 and 4 GHz 12 bit DSO's  (Read 70186 times)
Offline hpw
Re: Siglent SDS7000A 3 and 4 GHz 12 bit DSO's
« Reply #125 on: December 01, 2023, 05:40:08 pm »
>> 10Mhz clock which is -123dbm @ 1Hz no distribution
Yes, I have also such Sine based 50E OXCO as 120dBc @ 1Hz. IMHO other short time metrics important.
May test all individual inputs, as all should show up equal behavior Jitter values & graphs.
My SDA6xxx do show any different Histograms :palm:
>> However the Siglent 7000's base line spec I don't know...
Yes, very very pure ... as nothing of the Jitter Kit
Hp
Online Martin72
  • Testfield Technician
« Reply #126 on: December 01, 2023, 07:08:23 pm »
the 7000 is due here in the UK before Christmas so I will be spending some time with one very soon.
Oh yes....
(Kierkegaard)
Offline Sighound36
« Reply #127 on: December 02, 2023, 11:13:15 am »
Hwp
The reference clock is a square wave form, rather than a sine wave. I performed some indepth jitter & eye analysis on the unit a while back see below.
Martin
If the 7000 performs as expected I shall be purchasing one, as one of the chaps that works with keeps 'borrowing' my Wavepro HD  :-DD
The following users thanked this post: egonotto, Martin72, luudee
Offline pope
« Reply #128 on: December 02, 2023, 11:50:01 am »
May I ask why a scope would need a mic input and an audio output ?
Offline tautechTopic starter
« Reply #129 on: December 02, 2023, 01:15:43 pm »
Have you worked that out yet ?
This DSO is PC based and it is normal to have audio capabilities on a PC main board.
Offline pope
« Reply #130 on: December 02, 2023, 03:59:55 pm »
It is normal indeed. What I'm asking though is in which scenario an o'scope would need an audio I/O.
Online Martin72
« Reply #131 on: December 02, 2023, 04:18:39 pm »
You can't get a mainboard without these connectors.
They are simply there and are not used.
(Kierkegaard)
Offline Performa01
  • Country: at
« Reply #132 on: December 02, 2023, 04:43:04 pm »
There are applications imaginable.
A microphone could be used for audio notes accompanying screenshots for documentation purposes or even voice control for the instrument.
Headphones on the other hand can be used with each spectrum analyzer that has demodulation capabilities.
Maybe we'll see some of the above features in the future...
The following users thanked this post: pope
Offline hpw
« Reply #133 on: December 02, 2023, 05:55:41 pm »
@Sighound36
Very good ... a starting point for compare  ::)
Also 50E load enabled? And may tell what brand do you use?
Does SE-120 means WavePro HDO404 HD ??
>> SE-120 wavepro jitter kit
Do you get equal Histogram on each channels as Ch2, Ch3, Ch4 ??
>> SE-120 wavepro resjit histogram
May have to check its a part of the new SDA III or JitKit
As Teledyne JitterKit Paper, recommended to use 10 Wave Cycles ... and you use may 200 Cycles: Any reason for this?
Or do you have your own guidelines :D
Hp
Offline Sighound36
« Reply #134 on: December 02, 2023, 08:25:14 pm »
Hp
Yes 50Ohm impedance which is really essential for square waveforms where as sinewave it's much, much less critical imho.
I used full SDA linq with the new 10.5 FW and it's very very close on all channels. The jitkit is just a basic look but an accurate one in fairness.
In the new year the jitkit will be superceded by Clock xpert which will separate certain aspects of the SDA which will concentrate more on higher spec pcie/usb4/6G/ high speed serial data formats.
This I suspect is aimed at the new Wavemaster HD
Clock expert will include indepth eye analysis full jitter suite plus a new phase noise section incorporated.
I also have a Holzworth phase noise analyser and a UXA 50Ghz unit with phase noise app. So I have that aspect of measurement covered I feel.  Although Aaronia have some interesting products in the offing as well next year.
The label SE-120 refers to the clock's model number
Lecroys whitepapers are guidelines and each user I feel will adapt the settings for their own applications.
Our UK Lecroy reps are always on the lookout for tips and tricks to improve measurement ways and to reduce all operator error and refining the processes. Its a two way street.
I find the eye view & dual spectrum analyser option used in conjuction with a couple of RP4060 rail probes to view the clocks supplies rf noise sitting on the rails. On top of that a RTA with near field probes looking at clock radiated rf and board layouts can tell you a great deal inho
« Last Edit: December 03, 2023, 01:12:05 pm by Sighound36 »
The following users thanked this post: egonotto, luudee
« Reply #135 on: December 13, 2023, 04:18:55 am »
FYI
Siglent offer a SDS7000A product release promotion of free option licenses until June 30 2024.
https://int.siglent.com/info/detail-78.html
https://siglentna.com/news-article/siglent-sds7000a-introduction-promotion/
https://www.siglenteu.com/news-article/siglent-sds7000a-introduction-promotion/
Option                        Description
SDS7000A-FG   50 MHz built-in function generator
SDS7000A-16LA   MSO function (software), use with SPL2016 probe
SDS7000A-PA   Power Analysis: Power Quality, Current Harmonics, Inrush Current, Switching Loss, Slew Rate, Modulation, Output Ripple, Turn On/Off, Transient Response, PSRR, Efficiency
SDS7000A-I2S   I2S trigger & decode
SDS7000A-1553B   MIL-STD-1553B trigger & decode
SDS7000A-FlexRay   FlexRay trigger & decode
SDS7000A-CANFD   CAN FD trigger & decode
SDS7000A-SENT   SENT trigger & decode
SDS7000A-Manch   Manchester decode
SDS7000A-ARINC   ARINC429 trigger & decode (software)
SDS7000A-USB2   USB 2.0 decode (software)
« Last Edit: December 13, 2023, 06:48:44 pm by tautech »
Online Martin72
« Reply #136 on: December 13, 2023, 02:01:54 pm »
This promotion is only avaible in Asia, Africa and Latin Americas area
Possibly misinformation, because Batronix has had the bundle since the beginning:
https://www.batronix.com/shop/oscilloscopes/Siglent-SDS7304A-H12.html
(Kierkegaard)
« Reply #137 on: December 13, 2023, 06:00:55 pm »
This promotion is only available in Asia, Africa and Latin Americas area
Possibly misinformation, ........
Yours.  ;)
The promo is available in all regions.......yes I checked all 3 Siglent websites.
Additional links added above.
« Last Edit: December 13, 2023, 06:49:31 pm by tautech »
Online Martin72
« Reply #138 on: December 13, 2023, 06:14:31 pm »
When following your link, it is clear readable that is only for the mentioned regions.
They should correct this.
(Kierkegaard)
Offline EEVblog
« Reply #139 on: December 14, 2023, 12:10:05 am »
Interesting but not surprising that they switched from ARM to Intel core i5 and a standard motherboard. Would make development way easier, and cost minimisation really isn't a factor at this high end price point.
« Last Edit: December 14, 2023, 12:12:03 am by EEVblog »
Online KungFuJosh
  • TEAS is real.
« Reply #140 on: December 14, 2023, 01:07:25 am »
Might as well pay $50 for a motherboard if they're going to charge over $20,000 for the scope. 😉
Offline MathWizard
« Reply #141 on: December 14, 2023, 03:04:34 pm »
Has anyone tried hacking these yet to see if it can play Duke Nukem 3D ??
Offline Sighound36
« Reply #142 on: December 14, 2023, 03:11:10 pm »
Come on, Siglent are designed with hackability built in on all of their products those 7000 scopes will take a little longer to come to fruition as your average EEV Blog member isn't going to shell out on one for a hackaday project or maybe I'm wrong  :-/O :palm:
« Last Edit: December 14, 2023, 05:35:10 pm by Sighound36 »
Online Martin72
« Reply #143 on: December 14, 2023, 10:09:03 pm »
What would interest me is whether there could be more 12 bit models on the global market.
The Chinese have:
 -800X HD
-1000X HD
-2000X HD
-3000X HD
-6000 Pro H10/H12
-7000 A
"We" have:
-2000X HD
- 7000A
That's a bit meager...
While the 12-bit Siglent is represented in almost all price ranges on the Asian market, there is a huge gap between the 2000X HD and 7000A on the global market.
Which other manufacturers are filling, such as R&S MXO4.
I am happy with my 2504 X HD, but if I wanted "more" I would have to change brands, which I would find a shame.
(Kierkegaard)
Online nctnico
« Reply #144 on: December 14, 2023, 10:23:45 pm »
That probably has to do with Lecroy not wanting to have their share of the 12 bit market saturated. Problem with the cooperation between Siglent and Lecroy is that much what Lecroy tells to Siglent only applies to the market Lecroy is serving themselves. Keysight, Tektronix and R&S make oscilloscopes with a different phylosophy behind them so each fill different niches with the strong points of their devices.
« Reply #145 on: December 14, 2023, 10:25:04 pm »
The Chinese have:
 -800X HD
-1000X HD
-2000X HD
-3000X HD
-6000 Pro H10/H12
-7000 A
"We" have:
-2000X HD
- 7000A
For now.
2024 will be very different.
Online Martin72
« Reply #146 on: December 14, 2023, 10:43:29 pm »
Keysight doesn't even have any affordable 12-bit models, you can get them for several 10000€.
Tektronix is too expensive for what it offers, R&S is a ray of hope.
If you want something good from Lecroy, the minimum price is around €15,000.
In this respect, I'm a little surprised that Siglent is "allowed" to offer such a caliber as the 7000A here.
Or that the 2000X HD was allowed to come out here.
The obvious agreement is probably being softened somewhat.
For now.
I'll only believe it when I see it. ;)
The only thing Siglent EU has admitted so far is that an entry-level 12-bit scope will be released in the first quarter.
(Kierkegaard)
« Reply #147 on: December 14, 2023, 10:53:15 pm »
Think again all !
Refresh what you know and think from the info in post #60 !  :horse:
https://www.eevblog.com/forum/testgear/siglent-sds7000a-dsos-coming/msg4642900/#msg4642900
« Last Edit: December 15, 2023, 12:55:30 am by tautech »
Online Martin72
« Reply #148 on: December 14, 2023, 10:57:19 pm »
Did it.
Now.
(Kierkegaard)
« Reply #149 on: December 14, 2023, 11:10:20 pm »
Did it.
Now.
Explains lots, don’t it.  ;)
