Hi
I need some help.
I'm using the scopes automatic measurement function, looking at the 10-90% rise time measurement.
The measuement is super off. It is not showing correct at all.
A LeCroy wavesurfer is showing ~575ns 10-90% measurement which is pretty accurate compared to manually measuring with cursors.
The Siglent scope is showing 260-300ns using the 10-90% measurement
I try to change the threshold values between % and absolute values, no difference
I change the amplitude strategy between histogram and MAX-MIN values, no difference
I go to Analysis and change the analysis gate, no difference
I go to Analysis and change the histogram gates, no difference
Also the measurement values is constantly jumping on the y-axis
This is like the most standard easy measurement and this scope can't do it
