Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Siglent SDS3000X HD and upgraded SDS1000X HD
« previous
next »
Print
Search
Pages:
Prev
1
33
34
35
36
37
38
Go Down
Author
Topic: Siglent SDS3000X HD and upgraded SDS1000X HD (Read 416319 times)
pasha
and 1 Guest are viewing this topic.
Martin72
Super Contributor
Country:
Testfield Technician
Re: Siglent SDS3000X HD and upgraded SDS1000X HD
Reply #925 on:
Yesterday
at 05:37:07 pm »
What I noticed again yesterday is not an SDS3000X HD specific thing, but of a general nature with the software platform.
It concerns the display of the measured points:
I had also displayed the Stdev values from channel 2 and channel 3, later I no longer needed the two channels, so I had deactivated them again.
Accordingly, I no longer needed the values for 2 and 3, so I wanted to delete them....
It's not as simple as you might think at first.
You can only delete them all with "clear" in the measurement menu.
You can delete them individually by tapping the value for the relevant channel again, for example, in my case by tapping stdev again in the menu, then it's gone.
Now I could not delete stdev for channel 2 and channel 3, why ?
Quite simply because the channels are not active...
This means that to delete the measuring points, you must:
-reactivate the channels that are no longer required (and then deactivate them)
- or remember beforehand and delete the measuring points first, then deactivate the channels
- or delete everything with "clear" and create the measuring points for the active channels again.
Of course you can say that anyone who forgets will be punished, but you can also make it a little easier.
Measuring point n(value)(source) on/off, done.
Edit: B**sh** written.
Last Edit:
Yesterday
at 06:28:08 pm by Martin72
Logged
(Kierkegaard)
egonotto
Performa01
Super Contributor
Country:
Reply #926 on:
Yesterday
at 06:09:47 pm »
Quote from: Martin72 on
Yesterday
at 05:37:07 pm
... you can also make it a little easier.
Correct - you can make it a lot easier. No need to open the "Type" dialog. Just tap or click on the minus sign (in M1 mode the upper right corner of each measurement "box", in M2 mode in front of each measurement line).
Logged
egonotto
Martin72
Martin72
Super Contributor
Country:
Reply #927 on:
Yesterday
at 06:16:03 pm »
Hmm...
I pressed it yesterday, but only with my finger.
I'll try again soon.
Logged
(Kierkegaard)
egonotto
Martin72
Super Contributor
Country:
Reply #928 on:
Yesterday
at 06:26:54 pm »
Yes, that's right, it works if you hit the minus sign exactly, I couldn't manage that yesterday.
A slightly simpler operation would still not be bad, but that's complaining on a high level.
Logged
(Kierkegaard)
Performa01
egonotto
KungFuJosh
Print
Search
Pages:
Prev
1
33
34
35
36
37
38
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
