Author Topic: Siglent SDS3000X HD and upgraded SDS1000X HD  (Read 441624 times)
pasha and 5 Guests are viewing this topic.
Online egonotto
Re: Siglent SDS3000X HD and upgraded SDS1000X HD
« Reply #900 on: July 11, 2024, 09:20:55 pm »
Hello,
this looks similar to the error I had twice as far as I remember correctly. However, switching the device off and on always helped.
Best regards
egonotto
Online pasha
« Reply #901 on: July 11, 2024, 09:25:13 pm »
@egonotto,
But turning it off and on doesn't always work
Online egonotto
« Reply #902 on: July 11, 2024, 09:46:27 pm »
@egonotto,
Hello,
Does it help at least sometimes? If so, how often did it help and how often did it not?
I have now checked. It was on 25.5 and 20.6, so I only had the error twice. I hope it's not a hardware error. Have you contacted Siglent?
Best regards
egonotto
Online Martin72
  • Testfield Technician
« Reply #903 on: July 11, 2024, 09:59:14 pm »
This is all very strange and reminds me that I also wanted to test it on my scope.
Which I will do "tomorrow".
(Kierkegaard)
Online egonotto
« Reply #904 on: July 11, 2024, 10:14:17 pm »
Hello,
for me, the error occurs very rarely. Twice in six weeks. I had previously thought that it was a software error, but what pasha reports scares me a little.
I have no idea how I can reproduce the error. When I have had the error, it has always happened immediately after switching on. You can only see the error if you take a measurement.
Best regards
egonotto
Online Martin72
« Reply #905 on: July 11, 2024, 10:22:03 pm »
Just speculation, but it may have something to do with the internal calibration, which is displayed as finished 10 minutes after the start.
If it happens to me too, there are three different scopes where this has occurred.
Then you would have to make sure that you can actually reproduce it, i.e. at least the initial conditions must be the same for all of them.
But we are not there yet.
(Kierkegaard)
The following users thanked this post: egonotto, pasha
Online pasha
« Reply #906 on: July 11, 2024, 10:29:20 pm »
@egonotto, this is probably a bug, but I don't think I should worry about whether it's measuring correctly this time every time I turn on the oscilloscope.
Online egonotto
« Reply #907 on: July 11, 2024, 10:48:16 pm »
Hello,
I still haven't understood how often the error occurs with pasha. Is it always? Or most of the time?
If it occurs very often with pasha, he should contact Siglent. Looking for an error that occurs very rarely, as in my case, is extremely difficult.
Best regards
egonotto
Online egonotto
« Reply #908 on: July 11, 2024, 10:59:54 pm »
Hello,
another thing that surprises me, is how little influence the bandwidth limitation has on the noise.
Best regards
egonotto
Online pasha
« Reply #909 on: July 11, 2024, 11:03:25 pm »
@egonotto, %50   :palm:
Online Martin72
« Reply #910 on: July 11, 2024, 11:04:58 pm »
I could be wrong, but with the selected time base the lower frequencies tend to be dominant.
(Kierkegaard)
Online egonotto
« Reply #911 on: July 11, 2024, 11:16:45 pm »
Hello,
are the values for your device similar?
Best regards
egonotto
Online egonotto
« Reply #912 on: July 11, 2024, 11:22:22 pm »
Hello,
that's bad. Do you want to contact Siglent? Or do you want to complain to the dealer about your device?
Does the error sometimes occur even if the device has been running for a while without any problems?
Best regards
egonotto
The following users thanked this post: pasha
Online Martin72
« Reply #913 on: July 11, 2024, 11:28:09 pm »
We will see it later.
(Kierkegaard)
Online pasha
« Reply #914 on: July 11, 2024, 11:31:14 pm »
Hello,
Best regards
egonotto
yes, I will contact.
The problem starts when you first start up and continues until you restart. Sometimes it is necessary to reboot several times.
Online Martin72
« Reply #915 on: July 12, 2024, 12:02:54 am »
Proposal:
Switch on the scope and wait 15 minutes.
Then do what you always do.
(Kierkegaard)
The following users thanked this post: egonotto, KungFuJosh, pasha
Online Martin72
« Reply #916 on: July 12, 2024, 04:37:33 pm »
@egonotto:
What settings should I make on the scope for comparison?
(Kierkegaard)
Online egonotto
« Reply #917 on: July 12, 2024, 06:05:20 pm »
@egonotto:
Hello,
thanks,
channel 1: 1 V/div and channel 4: 1 V/div,
1 ms/div,
10 Mpts,
bandwidth limitation 20 MHz and 200 MHz,
Memory Management Auto, Max Mem Depth 10M.
Best regards
egonotto
Online Martin72
« Reply #918 on: July 12, 2024, 07:54:55 pm »
So I have now played around a bit.
Nothing "strange" has happened in the meantime.
But at first I didn't measure anything, nothing was displayed except ***- "thanks" to the new analysis gate. ;)
Then as specified 20M and 200M, looks normal compared to your measurements.
Interesting though:
This was measured in a cold state, after approx. 10min the now familiar message "Calibration completed" appears - And lo and behold....
Ch4 is now significantly better, has come much closer to CH1.
We should keep this in mind when "serious" measurements are due.
First of all, wait... 8)
Martin
« Last Edit: July 12, 2024, 08:05:57 pm by Martin72 »
(Kierkegaard)
The following users thanked this post: Performa01, egonotto, 2N3055, rfindley
Online pasha
« Reply #919 on: July 12, 2024, 08:05:09 pm »
Very sensitive multimeters had such a warning.
warm up time
Online Martin72
« Reply #920 on: July 12, 2024, 08:09:02 pm »
It should be noted that this message "Calibration Completed" is exclusive to the SDS3000X HD, it is not available on the 2000Xplus, 2000X HD, SDS800X HD.
But yes, a little hint, perhaps displaying "warmup" in a corner, that would be something nice.
(Lecroy scopes show this if you want to activate the self-calibration (is then blocked with the note)).
« Last Edit: July 12, 2024, 08:11:18 pm by Martin72 »
(Kierkegaard)
Online pasha
« Reply #921 on: July 12, 2024, 08:23:11 pm »
In fact, "warm up time" is valid for all oscilloscopes, even very old devices can be observed to behave differently 10 minutes after starting up compared to the beginning, specially in mV level measurements.
Online Martin72
« Reply #922 on: July 12, 2024, 08:30:36 pm »
There is no question that every appliance needs a certain warm-up time.
(Kierkegaard)
Online KungFuJosh
  • TEAS is real.
« Reply #923 on: July 12, 2024, 08:32:50 pm »
Yeah, tons of test gear require warm-up time. For example, the MXO 5 datasheet specifies:
"Three hours of storage at ambient temperature followed by 60 minutes of warm-up operation"
10 or 15 minutes isn't too bad. 😉
The following users thanked this post: egonotto, Martin72
Online pasha
« Reply #924 on: July 12, 2024, 08:42:27 pm »
