Author Topic: Siglent SDS3000X HD and upgraded SDS1000X HD  (Read 415786 times)
Offline Performa01
  • Country: at
Re: Siglent SDS3000X HD and upgraded SDS1000X HD
« Reply #650 on: May 21, 2024, 04:11:37 am »
what device did you use to generate these signals ?
It was an SDG6052X using the wave combine feature.
The following users thanked this post: kripton2035, egonotto, KungFuJosh, Martin72
Offline pasha
« Reply #651 on: May 21, 2024, 07:28:22 pm »
Hi everyone, is the hardware of SDS1000X HD and SDS3000X HD the same? thanks.
adc and main FPGA different?
« Last Edit: May 21, 2024, 07:34:21 pm by pasha »
Offline 2N3055
  • Country: hr
« Reply #652 on: May 21, 2024, 07:33:36 pm »
Very different actually.
The following users thanked this post: pasha
Offline pasha
« Reply #653 on: May 21, 2024, 08:09:29 pm »
Actually, they reduced the hardware of SDS1000x HD a lot, I didn't like it very much.
Offline ebastler
« Reply #654 on: May 21, 2024, 08:16:22 pm »
The price difference might have tipped you off.  ::)
Offline 2N3055
  • Country: hr
« Reply #655 on: May 21, 2024, 08:21:28 pm »
I don't understand correlation of your two posts...
Offline skander36
« Reply #656 on: May 21, 2024, 08:34:52 pm »
Reduced from what ?  :-//
Online Martin72
  • Testfield Technician
« Reply #657 on: May 21, 2024, 08:42:57 pm »
Unfortunately, this is the wrong approach.
The 1000X series was previously the entry series with good but limited models that reached up to 1Gsa/s and 14Mpts memory.
Now the 1000X HD has come onto the market.
It is so improved that it is no longer comparable to the predecessors of the 1000 series.
50Ohm inputs, autosense probes, 100Mpt memory, touchscreen, 10" display, more decoders, 4 channels of math, digital filters, etc, etc.
The 1000X HD is not reduced, it is the best 1000X model.
To compare it with the 3000X HD is simply not correct.
(Kierkegaard)
The following users thanked this post: Performa01, tautech, KungFuJosh, pasha
Offline pasha
« Reply #658 on: May 21, 2024, 09:12:16 pm »
@Martin72, you are right about the unfairness of the comparison. Actually, I will order sds3000x hd and I am afraid that it will be the same hardware as sds1000x hd, thanks.
« Reply #659 on: May 21, 2024, 09:39:58 pm »
:-DD
Nothing like the same !
C'mon study the datasheets.
Online Martin72
« Reply #660 on: May 21, 2024, 09:40:52 pm »
400Mpt maximum memory, 4GSa/s maximum sample rate (at least 2GSa/s), 350Mhz-1Ghz bandwidth, active probe interface, 1GBit LAN, USB3.0, integrated LA, 200000/890000wfms/s updaterate rate, more decoder, etc, etc...
No, the worry is unfounded. ;)
(Kierkegaard)
The following users thanked this post: tautech, pasha
Offline le_yum
« Reply #661 on: May 21, 2024, 10:38:29 pm »
Oh well...
You don't have to enlarge anything and/or put it in stop mode.
It is enough to change the vertical resolution from 100mV/div to 500mV/div.
Note also the frequency counter.
hello,
is the display of 1000HD same as 800HD?
« Reply #662 on: May 21, 2024, 10:42:53 pm »
hello,
No, 1k is 10", 800 is 7"
Offline le_yum
« Reply #663 on: May 21, 2024, 10:55:49 pm »
hello,
thanks, my question was about the pixelation:
OK, now I have understood it and have two sections (each 300% enlarged), left 800, right 3000.
« Reply #664 on: May 21, 2024, 11:04:18 pm »
It's something you can see if you go looking for it.
However in real use it's hardly ever a problem.
You could try a SDS802X HD @ just $339 then flick it if you can't work with it.
Offline ebastler
« Reply #665 on: May 22, 2024, 05:35:45 am »
It does become quite noticeable for signals with flattish slopes. As shown in Martin72's post which directly followed the one mentioned above:
Oh well...
It's an acceptable limitation for the 7" SDS800X HD. But if I had paid more than twice the money for an SDS1000X HD to get the 10" screen (plus 50 Ohm inputs), only to be shown those stair steps more clearly, I would probably be disappointed.
Offline le_yum
« Reply #666 on: May 22, 2024, 06:24:05 am »
Oh well...
thank you, that answered my question.
i also find the related discussion around page 11
« Reply #667 on: May 22, 2024, 07:19:18 am »
Oh well...
One need also consider with the prevalence of DDS signal generators today vs the analog of old, these DSO's are capable of showing modern equipment signal generation artifacts.
This might be a good test to do.......
Offline ebastler
« Reply #668 on: May 22, 2024, 07:41:39 am »
You mean, those stair steps shown by Martin might be real signal components caused by a digital signal generator? No way. (a) The step height on the SDS800X HD screen corresponds to approx. 8 bit resolution only -- the SDG2042X is "slightly" better than that. (b) The SDS3000X HD, which uses its full screen resolution, shows a smooth slope as expected.
The following users thanked this post: le_yum
« Reply #669 on: May 22, 2024, 08:00:33 am »
Yeah well from Siglent's own website blurb, 14 vs 16bit = SDG1000X vs SDG2000X
Everyone pull out their old linear FG's and compare.
I wonder if my old HP still works.  :horse:
https://www.eevblog.com/forum/testgear/hp-8654b-10-520-mhz-sig-gen-light-teardown/
« Last Edit: May 22, 2024, 08:04:41 am by tautech »
Offline ebastler
« Reply #670 on: May 22, 2024, 10:24:29 am »
Sure. But that's a red herring in the context of the cut-in-half vertical resolution for trace rendering in the SDS800 and 1000X HD scopes. The steps which are visible on-screen, especially notable for traces with flat slopes, have nothing to do with the actual signal but are a limitation of these scopes.
Offline skander36
« Reply #671 on: May 22, 2024, 10:45:39 am »
This is not a limitation, it's just an aesthetic issue. I'm using the scope very well. It's not good looking but from usability perspective the scope main function is not affected in any way. You should stay with Rigol if this is important for you.
As a parenthesis I am keeping Rigol DHO1000HD.
« Last Edit: May 22, 2024, 10:58:19 am by skander36 »
Offline ebastler
« Reply #672 on: May 22, 2024, 12:50:13 pm »
Of course it is a (technical) limitation: The scope is not able to make full use of its screen resolution when rendering traces.
Whether you feel that it is affecting your use of the scope is another matter. As I have said before, I personally find it acceptable on the SDS800X HD -- but consider it a poor design tradeoff for the SDS1000X HD, where Siglent charges a heavy markup for the larger screen (and 50 Ohm intputs).
The following users thanked this post: egonotto, Jacon
Offline skander36
« Reply #673 on: May 22, 2024, 01:04:56 pm »
... As I have said before, I personally find it acceptable on the SDS800X HD -- but consider it a poor design tradeoff for the SDS1000X HD, where Siglent charges a heavy markup for the larger screen (and 50 Ohm intputs).
For me a 7" scope is a no go for this days. Adding that 800X-HD has an ugly and old design made me to choose 1000X-HD over 800X-HD despite the higher price.
At that moment I've could buy 800X-HD, and also 2000X-HD but my choose was 1000X-HD and I didn't find any reason to regret, but on the contrary.
Regards
Offline le_yum
« Reply #674 on: May 22, 2024, 01:40:58 pm »
i wanted to pay an extra if the 1000hd had not the blobby pixels. 2000hd is too expensive & not justified for my usage.
maybe i can live with the 512x300 resolution... my old tektronix is 320x240 :D
does it have the same double pixel behavior in fft mode?
