Author Topic: Siglent SDS3000X HD and upgraded SDS1000X HD  (Read 425547 times)
0 Members and 13 Guests are viewing this topic.
Offline KungFuJosh
  • TEAS is real.
Re: Siglent SDS3000X HD and upgraded SDS1000X HD
« Reply #550 on: April 26, 2024, 01:54:41 pm »
I'm not a somnambulist
Are you sure you haven't sleep walked into a manual or two? 🤣
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
The following users thanked this post: Performa01
Offline 2N3055
  • Country: hr
« Reply #551 on: April 26, 2024, 02:18:45 pm »
A somnascriptor ?? :-DD
The following users thanked this post: temperance, KungFuJosh
Online Martin72
  • Testfield Technician
« Reply #552 on: April 26, 2024, 09:04:02 pm »
It would be great if performa01 would contribute to the manuals.
The documentation is something that, in my opinion, is not yet running smoothly at Siglent.
Be it that the manuals are not updated after various feature upgrades.
Or that certain special functions are not sufficiently explained.
If there are application notes for this, it would be nice if there was at least a reference to this.
(Kierkegaard)
The following users thanked this post: egonotto, ebastler, 2N3055, KungFuJosh
Offline temperance
« Reply #553 on: April 26, 2024, 11:07:24 pm »
I just tried the new software released by Siglent sigscopelab.
But this software seem to require some work.
-Setting the time base cycles the time base on the remote device between 1 s, 2 s, 10 ns instead of following the required setting.
-The application frequently freezes, a command window appears and disappears.
I didn't do any further tests.
Also, this is a free version. I hope they are not planning to release sub standard node locked pay ware like other brands do.
Offline KungFuJosh
  • TEAS is real.
« Reply #554 on: April 26, 2024, 11:17:29 pm »
It needs a lot of work, but it's free (at least for now). I tried it with my SDS2504X+, and it worked pretty well, but putting the scope in 10 bit mode made it crazy.
Online DaneLaw
« Reply #555 on: April 27, 2024, 01:44:05 am »
The following users thanked this post: egonotto, Mortymore, KungFuJosh, Martin72, core, Coder69, trackersoft, Ulrich.G
Offline KungFuJosh
  • TEAS is real.
« Reply #556 on: April 27, 2024, 03:07:27 am »
Nice! Biggest issues I saw:
5:05 didn't know the difference between the internal LA hw or external LA hw connections...
11:32 still didn't know LA hw is external, assumes the zynq chip is handling the LA stuff.
If you don't want to RTFM, look at the product page quickly and you can see the external logic hardware listed.
The following users thanked this post: egonotto, Martin72
Offline ebastler
« Reply #557 on: April 27, 2024, 04:00:25 am »
As expected, the core architecture seems very similar to the 800X HD series. The front ends differ, of course, due to the 50 Ohm support in the 1000 series.
I am still puzzled by the dual ADCs. Why did Siglent splash out on those, given that the total sampling rate across all active channels is always 2 GSa/s maximum in the SDS1000X HD? Does this imply that the scope could technically run at 2*2 GSa/s (or 4*1 GSa/s) and is just throttled to keep the higher-end models differentiated?
It's the same for the 800X HD platform, of course. But I don't think we ever reached a conclusion there?
« Last Edit: April 27, 2024, 04:19:32 am by ebastler »
Online Martin72
« Reply #558 on: April 28, 2024, 10:04:48 pm »
I would rather enjoy the fact that there has never been so much “scope” for the money as there is now, instead of brooding about it.
Not so long ago, the 12-bit ADCs used were cited as one of the reasons why the 2000X HD was twice as expensive as the 2000X plus.
Now you can get them in a 500€ model. ;)
(Kierkegaard)
The following users thanked this post: egonotto, 2N3055, Mortymore, KungFuJosh, Bad_Driver
Offline ebastler
« Reply #559 on: April 29, 2024, 05:31:00 am »
Who's brooding? I am just curious why certain design decisions were made and what they imply. Maybe there is something to be learned?
Let's face it, most of our threads here are about "scopology" rather than about using the scopes in practice. (Which is fine by me, there are Project setions etc. which discuss the latter.) No doubt that we get excellent affordable scopes today, which most of the time we won't even use at their full potential. But what's wrong with also being curious about how they work, how they were designed and why? The Test Equipment section would be pretty quiet otherwise.
The following users thanked this post: Electro Fan, skander36
Offline core
« Reply #560 on: April 29, 2024, 06:41:10 am »
I'm waiting for a teardown showing which FPGA and ADC are used in the SDS800X HD. The ADC converter seems to have the smaller capsule vs the SDS1000X HS, but the FPGA might be the same.
Indeed, it's a shame to waste resources, in the sense of not making full use of the ADC converter. 2 x 2GS/s would have made more sense.
If there were limits in the FPGA for example, it would have been logical and cheaper to use an ADC with 4 x 1GS/s channels in the same capsule.
However, we can still enjoy these devices considering the price/performance ratio.
Offline skander36
« Reply #561 on: April 29, 2024, 10:12:44 am »
I see two reasons. One or both can be true:
One as you said, the configuration is chosen to create a gap between models.
Or the ADC is configured so, because the FPGA does not have enough resources to process data from 2X2 GSPS.
The double ADC indeed should be capable of a max. 2x2 GSPS in dual ADC config or 4 GSPS in interleaved mode.
The following users thanked this post: ebastler
Offline BreakingOhmsLaw
  • Certified solder fume addict
« Reply #562 on: April 29, 2024, 06:55:20 pm »
This, Twice.
A 200MHz 12 bit scope is more than enough for 99% of hobbyist. 25 years ago, digital scopes were in the "small house" price range.
My first privately owned scope in 1995 was a 15MHz analog boat anchor, barely enough bandwidth to service a television.
I could take the 1204X-HD to work and still happily do my job with that. Hell, the R&S I use at work has 10 bits only.
The following users thanked this post: Performa01, egonotto, 2N3055, Bad_Driver
Offline tv84
  • Country: pt
« Reply #563 on: April 29, 2024, 08:23:34 pm »
The .bit inside the 800/1000X HD FW package is for a Zynq 7z020clg484.
The following users thanked this post: egonotto, core
Offline tv84
  • Country: pt
« Reply #564 on: April 29, 2024, 09:20:43 pm »
SDS 3000X HD has
Product_ID: 18601
and filesystem contains this password:
root:$5$4se6aot/c2tWs2Lm$UvRirGQV4dp9ytuaWjrbhyqy.glwqqVT8wtMRnc8a57:::::::
Uses Licenses v2.0.  ;)
The app contains references to a new Siglent device's internal name:
HULUWA_2CH
HULUWA_4CH
(don't know if it's one of the recently released as I haven't looked at Siglent's for quite awhile)
« Last Edit: April 29, 2024, 09:37:35 pm by tv84 »
Offline tautech
« Reply #565 on: April 29, 2024, 09:44:02 pm »
HULUWA_2CH
HULUWA_4CH
The new to come 6&8 GHz models ?
https://www.siglent.com/products-overview/sds7000a/
Out of office and unavailable for a few days.
Offline tv84
  • Country: pt
« Reply #566 on: April 29, 2024, 10:02:08 pm »
First time I see BW references inside Siglent's FW going up to 16GHz !!!
The following users thanked this post: rf-loop, Performa01, egonotto, tautech, KungFuJosh
Online Martin72
« Reply #567 on: May 01, 2024, 09:08:14 pm »
Bodnarpulse on the SDS3034X HD, risetime about 830ps.
(Kierkegaard)
The following users thanked this post: Performa01, egonotto, Ulrich.G
Offline hpw
« Reply #568 on: May 02, 2024, 06:19:03 am »
This means, any 20..40Gs gear to come. Than we go with Bodnarpulse to the real 30ps risetime  :-DD
Requires any better based oscillator & synthesizers as in fs... just look at LeCroy HD series. To get any trusted Jitter figures.
Offline tautech
« Reply #569 on: May 02, 2024, 06:27:14 am »
Already available.  :P
https://siglentna.com/product/precision-frequency-reference/
« Last Edit: May 02, 2024, 06:33:27 am by tautech »
Offline hpw
« Reply #570 on: May 02, 2024, 07:27:15 am »
Any trusted or valid company would provide any PN figures of the OXCO. In addition any ventilation as vibrations from the gear will reduced the performance of the OXCO to death.
This means also, double oven would reduce the any environment temperature changes.
IMHO, it looks like cheap AliExpress thinking's as no valued gear. While even no performance/improvements & data's provided.  :palm:
Hp
Offline tautech
« Reply #571 on: May 02, 2024, 07:38:22 am »
Tis in the datasheets for the instrument it fits:
OCXO option
Frequency 10M Hz
Initial accuracy -100 +100 ppb 25 ℃
Temperature stability -1 +1 ppb 0 ~ 50 ℃
1st-year aging -50 +50 ppb
The following users thanked this post: egonotto, KungFuJosh
Offline KungFuJosh
  • TEAS is real.
« Reply #572 on: May 02, 2024, 01:36:26 pm »
RTFM / RTFDS?? We have to read to get info now??  :palm: :palm: :palm:
Offline ebastler
« Reply #573 on: May 02, 2024, 01:36:43 pm »
OCXO option
Frequency 10M Hz
I think you are talking about two different requirements here. The optional OXCO seems designed to provide precise and long-term stable frequency, if you want to measure absolute frequencies with the scope. hpw was asking about low jitter and low phase noise, for use as a timebase for very fast acquisition.
Offline ebastler
« Reply #574 on: May 02, 2024, 01:37:50 pm »
I would curse more quietly in your place, since you apparently did not read hpw's question.  ::)
