Author Topic: Siglent SDS3000X HD and upgraded SDS1000X HD  (Read 439640 times)
pasha and 1 Guest are viewing this topic.
Offline Martin72
  • Testfield Technician
Re: Siglent SDS3000X HD and upgraded SDS1000X HD
« Reply #975 on: September 06, 2024, 09:50:38 am »
Then he doesn't need to compare anything if the basic conditions are different.
Strange.
Maybe I'll be lucky and he'll answer my question.
(Kierkegaard)
The following users thanked this post: Someone, egonotto, KungFuJosh
Offline Bad_Driver
« Reply #976 on: September 06, 2024, 11:32:17 am »
„Everything must be made as simple as possible. But not simpler.”
― Albert Einstein
The following users thanked this post: egonotto, KungFuJosh, Martin72
Offline egonotto
« Reply #977 on: September 06, 2024, 06:05:50 pm »
Hello,
I think we can all agree that the result Dave showed doesn't show the advantage of 14 bit, right?
Best regards
egonotto
The following users thanked this post: Performa01, Bad_Driver
Offline Martin72
« Reply #978 on: September 06, 2024, 08:49:17 pm »
With reference to his statement in the video “And this is the difference between 14 and 12 bit ADC”, we have confirmed that this is not the case.
(Kierkegaard)
The following users thanked this post: Performa01, egonotto
Offline kripton2035
« Reply #979 on: September 07, 2024, 07:48:26 am »
I recall he compared the output of the 14bits keysight and the 12bits R&S, with the small 50MHz FFT pulse signal.
but we see now that with a 12bits siglent HD we can see this small signal in the same conditions...
so where is the 14bits advantage ?
Offline Performa01
  • Country: at
« Reply #980 on: September 07, 2024, 08:38:42 am »
At high sensitivities like 1 mV/div, the dynamic range is determined solely by the frontend noise. Even a totally noise-free 50 ohms system (resistive noise only) cannot provide even 7 bits of dynamic at 1 GHz bandwidth. At 500 MHz it is still less than 8 bits. In practice, even the lowest noise frontends exhibit at least twice as much noise as in the previous calculation, thus reducing the dynamic by another bit. Therefore 14, 12, 10 or even 8 bits don’t make the slightest difference at 1 mV/div.
The FFT reduces the bandwidth, hence lowers the noise, so we can get more dynamic range for individual frequencies. But this is due to the process gain of the math operation and does not benefit from more ADC-bits either.
The real difference can only be seen at the lowest sensitivity without attenuator, like 100 mV/div on the Siglents. Once again, with a noise-free Frontend, we could get 13 bits of dynamic at best. With a real low noise frontend and 2 nV/√Hz the dynamic is limited to 12 bits at 1 GHz bandwidth.
Higher bit counts may be beneficial at lower bandwidths, down to 10 MHz at best, but not lower, because the noise floor rises significantly at lower frequencies. At 100 mv/div and 20MHz bandwidth, we could make use of 15 bits if we have a very low noise frontend with only 2 nV/√Hz at 20 MHz. But even at such low bandwidths, it is less than 9 bits at 1 mV/div.
Long story short: for 1 GHz bandwidth, 12 bits is the absolute maximum sensible resolution, fully exploitable only in three vertical gain settings: 100 mV, 1 and 10 V/div. More than 12 bits make sense only for low bandwidths and low sensitivities of 10 mV/div and above. Thus 14 bits is of very limited value on a general purpose DSO.
« Last Edit: September 07, 2024, 08:41:45 am by Performa01 »
The following users thanked this post: kripton2035, egonotto, tv84, 2N3055, famalex, Jacon, Grandchuck, Martin72, core, Bad_Driver, ballsystemlord
Offline hpw
« Reply #981 on: September 07, 2024, 09:05:07 am »
At high sensitivities like 1 mV/div, the dynamic range is determined solely by the frontend noise.....
One important thing to consider as to use sample "AVERAGING" !!
Using my LeCroy WM or SDA, I have to use at least of an minimal 4 times averaging, otherwise the noise gets to high.
Just to measure the rtHz FFT figures, a high amount of averaging is a must use. As you did already.
Offline Bad_Driver
« Reply #982 on: September 07, 2024, 12:30:50 pm »
I went trough the HP/KS HD3 datasheet and tried to do some measurements to compare my SDS2000 HD with the published datas. Some results will follow.
But I‘m wondering if it is possible to get with FFT and Math channels rtHz Power density values from the 2000/3000 HD?   :-//
I found the following LeCroy paper:
https://www.teledynelecroy.com/doc/noise-measurements-using-your-lecroy-oscilloscope
but I‘m a little bit lost after figure 6 or 7….. :phew:
Can one of our well known expert explain if this is possible and if „yes“ how to do that?
PS: I saw the yt video from the IMSAI guy on zone triggering with the HD3. I‘m pretty happy to have this with the SDS2000/3000 HD series and before with my SDS2000X + for some time :-DD
Thanks in advance!
« Last Edit: September 07, 2024, 12:33:02 pm by Bad_Driver »
― Albert Einstein
Offline Martin72
« Reply #983 on: September 07, 2024, 01:59:35 pm »
I think this should also be posted in the Keysight HD3 thread.
(Kierkegaard)
The following users thanked this post: egonotto, KungFuJosh, Bad_Driver
Offline Martin72
« Reply #984 on: September 07, 2024, 08:00:30 pm »
Just for fun, SDS1104X-E.... ;)
4µV/50Mhz.
The view should be enjoyed with a little caution, as the SDS1104X-E already displays various interference spectra in this range, even if no generator is active.
(Kierkegaard)
The following users thanked this post: Performa01, Someone, egonotto, 2N3055
Offline Someone
    • send complaints here
« Reply #985 on: September 07, 2024, 10:10:33 pm »
4µV/50Mhz.
With a Δf of 7-8kHz many scopes can get that (not)special -105dBm including the "noisy" predecessor from HPAK. This is why the settings/configuration are so important to make the same in a fair comparison.
Sample rate, channel bandwidth, FFT length, averaging (or not), hi-res (or not), and how all of those change the bandwidth of the final measurement.
The following users thanked this post: Performa01, egonotto, 2N3055, Martin72
Offline Martin72
« Reply #986 on: September 07, 2024, 10:14:25 pm »
Like I said, just for fun...
We won't find out the right settings like in the video any time soon, because he has forgotten them...
(Kierkegaard)
The following users thanked this post: Someone, egonotto, 2N3055
Offline Dennis Frie
« Reply #987 on: September 20, 2024, 08:01:12 am »
Am I the only one being slightly annoyed by the constant 6.1 kHz tone from the oscilloscope (SDS3034X HD)? It's not related to the AC voltage, so I assume it's one of the small DC-DC supplies not being loaded. Loading the 5V USB supply doesn't help. Might be one of the supplies for active probes...
« Reply #988 on: September 20, 2024, 08:22:56 am »
Share more info please....
Offline Dennis Frie
« Reply #989 on: September 20, 2024, 08:27:42 am »
At least from my scope, there's a constant audible 6.1 kHz tone. Not loud enough to be a huge problem, but pretty annoying none the less.
Wondering if it's a general "design flow" or just my scope.
« Reply #990 on: September 20, 2024, 08:36:29 am »
Can you really hear -45dB ?
Have you tried an audio analyzer app on your phone or tablet ?
Tell us what happens when you set Sound = Off.
Offline Dennis Frie
« Reply #991 on: September 20, 2024, 08:45:28 am »
Yeah it's audible when sitting at my other desk ~3 meters away. The picture attached in the previous post is indeed just captured from an audio analyzer app on the phone. The phone app also shows the 6.1 kHz peak just fine at a few meters distance.
I can't seem to find the "Sound off" option? But it's constant, even with the channels disabled, scampling stopped etc.
« Last Edit: September 20, 2024, 08:47:06 am by Dennis Frie »
« Reply #992 on: September 20, 2024, 08:52:29 am »
Utility/System settings/Beeper
Result please ?
Offline Dennis Frie
« Reply #993 on: September 20, 2024, 08:55:28 am »
Same result unfortunatly...
Loading the +/- 12V AUX output didn't change anything either.
However, changing the LCD brightness does. If I set the LCD brightness to 0%, the tone is gone. Not really an option as it's almost impossible to see anything on the screen, but at least that seems to narrow it down.
« Reply #994 on: September 20, 2024, 08:57:44 am »
Please attempt to find a acceptable noise threshold and advise.
Offline 2N3055
  • Country: hr
« Reply #995 on: September 20, 2024, 09:08:00 am »
Result please ?
It has nothing to do with sounds of the scope.
I never was bothered by it because I don't hear it.
So I went and measured.
At 1m distance there is slight peak at cca 6kHz but that one is at -88dB ..... So 4 orders of magnitude less than what you have. No wonder I can't hear it.
To investigate further with phone stuck right at the scope, touching it. So there is mechanical transfer too, so worst case scenario acoustically. It was no worse than -67dB.
That is 2 orders of magnitude less that what you claim at some meters.
And it is connected with screen backlight, by the way...
It is not a functional problem. It is not a general problem. It seem to be your particular scope combined with your sensitive hearing that is unlucky combination.
If it bothers you that much, please present the problem to Siglent support through vendor you purchased it from. I'm sure they will find some way to help you.
« Last Edit: September 20, 2024, 09:14:52 am by 2N3055 »
Offline Dennis Frie
« Reply #996 on: September 20, 2024, 09:13:21 am »
Anything above 10-15% screen brightness and the tone is audible. 100% brightness is actually slightly better than 50% or so.
For now, I guess 100% screen brightness is the best compromise. I will consider to send it back for replacement/repair, as it's pretty annoying when working in the lab.
« Reply #997 on: September 20, 2024, 09:16:04 am »
Result please ?
100% but still possibly a design problem and we need to listen and feedback to HQ for their deeper tests...
Offline Dennis Frie
« Reply #998 on: September 20, 2024, 09:25:32 am »
Result please ?
I will get in contact with the distributor, I was mainly curious to find out if it's a general problem or specifically related to my scope. Thanks for your inputs
Offline Dennis Frie
« Reply #999 on: September 20, 2024, 09:37:58 am »
If it's related to the PWM frequency of the LCD dimming, it would be amazing if it can be fixed in a software update ;D. I guess 100% brightness is still dimmed to some degree, to get proper lifetime on the LCD.
