A few impressions....
This refutes the data sheet regarding the bandwidth specification when 2 identical channels are active, it is 750Mhz, not 800Mhz.
Risetime is impressively low, the higher bandwidth naturally has an effect on the overshoot.
More pictures:
Intrinsic noise at 1V/1MOhm/full bandwidth, as well as various other settings, plus an FFT of the bodnarpulser, 10Mhz center, 100kHz span, flattop.
