I couldn't find remote commands for WaveGen option. True, you can control it remotely from EasyScopeX via Virtual Panel, but there are no listed commands in scope's programming manual. So I sniffed the USB communication and determined the commands sent from computer while using EasyScopeX's Virtual Panel. The commands are equivalent to front panel button presses. While this can be tiring in some cases, e.g. when typing in desired frequency, it is still useful.
For all buttons and knobs command syntax is
SY_FP n,m
where n is a number unique for every button, and m can be -1, 0 and 1. For all simple buttons m is always 1. For turning knobs for cw turn m is 1, for ccw is -1, and for pressed knob 0.
For example to press Run/Stop button command is SY_FP 12,1
I have attached SDS2304X front panel picture with (almost) all buttons numbered.
I hope someone will find this helpful.
Best regards.
__________________________________
EDIT
The good guys from Siglent sent me the commands list. I attached them bellow. This makes the info above redundant but...
Regards.
