I tried the EasyScopeX software again. This time with a USB cable but still no go. The software from NI sees the oscilloscope fine but no go with EasyscopeX.
edit: I downloaded the latest version of EasyscopeX (which now also includes the NI Visa runtime) and that seems to work with USB. LAN is still no-go. The oscilloscope is detected but I get an error saying that 'error_log.txt' is locked because it is used by a different process when I try get a screendump. I really like to see the LAN interface working.
edit2: I also see something is wrong with the USB interface as well. I keep getting messages that the oscilloscope is a full speed (which means USB2.0 480Mbit) device but that it cannot work at that speed so the data transfer is slower than necessary (12Mbit instead of 480Mbit). Yes, I tried several cables and hubs.
LAN
(for others to see as well.
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
From Easyscope select Add Device.
Select Bus/Connection type: VX11
Ensure the scope IP address in Easyscope matches the scope IP (accessed from Utility/ I/O / LAN menu.
Set DHCP to Enable.
Should look like this in the Easyscope Scope Explorer pane:
SDS2304 Active VX11 TCPIPO::192. 1**.*.***::inst0::INSTR SDS200**********
Select Send Commands and choose *IDN? which then appears in the Send Commands pane.
Press Enter for your scopes ID and this should appear in the pane below.
For example try a ASET command typed into the Send Command pane for the scope Auto Setup.
USB
Be sure to select the USBTMC connection/bus type
SDS2304 Active USBTMC USBO::***********::INSTR SDS200**********
Then select the Virtual Panel button in the above ribbon for a window that allows mouse control of the full features of the scope.
(PC used: I3 3.3G Win 7 64 bit)
nctnicoI have not tried USB 1 for Easyscope control, only USB 2, have you checked your PC USB hubs in Device Manager are USB 2 compliant and have updated drivers?
Nor have I tried connection through a USB hub.
For me it works as expected.
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
