Equipment: Rigol DSA815, EMI precertification test software, a bicon, a log, a preamp, and a comb generator.
Hello, everyone. I considered posting this topic in the Newbie forum, but my situation seems to be more specifically related to what's discussed here. I apologize if this is inappropriate, and will close the topic and move it if needed. Please bear with me if anything I say is either extremely obvious or just flat out wrong.
I work as an electrical assembler for a small company building light-industrial laser automation systems. Recently the owner of the company tasked me with EMI pre-certification of systems that will be subject to CE testing. I'm already in way over my head and have received very little training on how to actually do this.
Here's what I know:
I need to use a spectrum analyzer to determine that the Qpeaks of the radiated emissions fall under acceptable limits for EN55011. Our systems are considered to be Class A Group 1, and I'll be testing at a distance of 3m. This gives me a limit of 50dBuV/m for 30-230 Mhz, and 57dBuV/m for 230Mhz-1Ghz.
Here's my test setup:
I'll be testing the system in situ in an empty warehouse across the street. Not the best environment, I'm sure, but it is what it is. I'll be using a 48v PSU to drive an inverter in order to step the AC frequency down to 50hz, as this system is going to Europe. Inside the system is a 650w PSU and a 40w CO2 laser with an internal RF driver. I am not using the preamp right now because I don't fully understand what it's for or how it works.
Here are my analyzer settings:
This is what really has me scratching my head:
This is my baseline ambient reading with all the equipment under test unpowered. No matter what I do, the reading is always the same. Regardless of whether I'm using the bicon or log, whether or not all equipment under test is powered on, or whether I'm firing the laser at full power. Unless this is the quietest equipment on the planet, I feel like I must be doing something wrong. Not only that, but it appears that the ambient noise is already pushing me over the 50dBuV/m limit in the 30-230Mhz range.
I feel like I should have correction files set up for things like the antennas, the cable, a preamp, etc.
Thanks very much in advance.
