I like the 10 bit "Hi Rez" feature, also the larger screens of this series. Of course 4 channels is better than 2, but costs more!! I'm also interested in an the AWG and PS, although these are not as important as the scope. I have a couple repaired Tektronix 2465s, and an older LeCroy "digital" scope, but wanted something I could do some serious signal analysis with including FFTs. The idea of being able to "capture" a complex waveform and then pass in on to the AWG for reproduction is interesting, as well as the Bode plots.
There are so many options, mostly all good from various sources, it's hard to make a choice. In my days when employed it was simply Tek scopes, Fluke or HP meters and everything else HP. Now on a home brew budget, this isn't reasonable unless you get older "surplus" equipment and repair like we've done. Still think the old Tektronix 2465 types scopes are the best analog scopes ever, and the old HP 34401A and it's modern version the Keysight 34465A are the best bench DVMs available, but with the lower end digital scopes there are so many options. Same goes for the AWG and PS options. Must be fun for a younger engineer with all these options available.
Anyway, thanks for the reply and info.
Also like to hear options from valid sources regarding AWG and PS, but that's for another thread.
Best,
