Author Topic: Siglent SDS2000X Plus Hack  (Read 202466 times)
0 Members and 21 Guests are viewing this topic.
Online KungFuJosh
  • TEAS is real.
Re: Siglent SDS2000X Plus Hack
« Reply #525 on: July 11, 2024, 11:04:31 pm »
I was able to update my brand new SDS2104X plus with latest software version 1.6.2R1
That's not the latest version.
« Reply #526 on: July 11, 2024, 11:12:18 pm »
;D
Sometimes dealer websites do not provide links to the latest upgrades so we are best to use the official Siglent websites.
V1.6.2R5 is the latest SDS2000X Plus firmware version.
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS2000X%20Plus_V1.6.2R5_EN.zip
Offline Anlefu
  • Country: cn
« Reply #527 on: July 29, 2024, 08:25:47 am »
Hello, will be there any potential risk for update from 1.6.2R1 to 1.6.2R5? I have a SDS2074X(and already hack to SDS2504X).
could you help me? or any others have verify this update.
Online coromonadalix
« Reply #528 on: July 29, 2024, 11:42:22 am »
normally Siglent does not block any "hack" done before fw updates
done many fw updates on our Siglents,  no problems so far
The following users thanked this post: Anlefu
Online KungFuJosh
  • TEAS is real.
« Reply #529 on: July 29, 2024, 02:27:46 pm »
It's not actually a hack. The numbers used are the same numbers Siglent would provide to you. There's nothing for new firmware to block or care about.
Offline Jack24044
« Reply #530 on: August 22, 2024, 10:06:52 am »
There's a new option for SDS2000X Plus, fw 1.6.2R5: ARINC.
https://en.wikipedia.org/wiki/ARINC_429
Adding 'A429' to the bwopt variable in the script gives the correct key.
« Last Edit: August 22, 2024, 12:23:26 pm by Jack24044 »
Offline danieljfarrell
« Reply #531 on: September 05, 2024, 09:17:28 am »
Hi everyone,
  • If the hack is applied to the SDS2104X Plus (100MHz), I think I need to upgrade to first to 250MHz and so on. What is the highest bandwidth that can unlocked for this scope?
  • I would like the I2S decode, does the hack also unlock that?
Thanks,
Offline tv84
  • Country: pt
« Reply #532 on: September 05, 2024, 09:37:57 am »
1 - Apply the max BW license directly.
2 - Must insert the corresponding license (I2S).
« Reply #533 on: September 05, 2024, 06:28:12 pm »
Thanks!
1 - Is there a hardware limitation to bandwidth? How high can the 100MHz scope be bumped?
2 -  |O well OK I suppose :)
Offline Mahagam
« Reply #534 on: September 05, 2024, 07:43:42 pm »
1. Front-end can be based (for example) on LMH6518. Read the datasheet.
Online KungFuJosh
  • TEAS is real.
« Reply #535 on: September 05, 2024, 08:34:04 pm »
It's a 500MHz hardware platform.
Offline sarahMCML
« Reply #536 on: September 06, 2024, 05:55:48 pm »
I've not made any updates to my scope, apart from the various function upgrades, since I purchased it.
Its currently running Software version 1.3.7R5, U.Boot 5.0, and the Hardware Version is shown as 02-04.
Are there any problems that I will run into if I try any updating, and what should I update. I have to admit I'm at a loss on how to go about it!
« Reply #537 on: September 06, 2024, 09:22:52 pm »
Uboot needs updating tp 5.4
It’s done at boot like a recovery package, just follow instructions:
https://siglentna.com/download/44461/?tmstv=1725657180
Then update to latest firmware:
https://siglentna.com/download/44012/?tmstv=1725657180
Sorry about the US links…..easiest when on iPad for a couple days.
Offline sarahMCML
« Reply #538 on: September 07, 2024, 12:24:51 am »
Many thanks, Tautech. I take it that the Hardware Version won't make any difference then?
« Reply #539 on: September 07, 2024, 06:03:23 am »
None at all.
If we look closely at FW revisions and their notes we often see mention HW version compatibility and even small HW changes are happening regularly so all FW versions need to be compatible.
Nothing at all to worry about.
« Last Edit: September 07, 2024, 07:08:03 am by tautech »
Offline sarahMCML
« Reply #540 on: September 07, 2024, 11:07:31 am »
Many thanks once again,Tautech. The updates went like a dream!
Offline BillyO
« Reply #541 on: September 08, 2024, 05:49:56 am »
No, don't.  This does not work.  Apply the 350MHz license first, then the 500Mhz.  They do different things and both are required.
There is a reason why there is no direct upgrade from 100 to 500 or 200 to 500.
If you just install the 500MHz license, your scope, while not broken, will not work properly.
Of course, you can just ignore me if you like.  Have fun!
