Author Topic: Siglent SDS2000X Plus Hack  (Read 197065 times)
0 Members and 18 Guests are viewing this topic.
Offline BillyO
Re: Siglent SDS2000X Plus Hack
« Reply #500 on: January 09, 2024, 09:32:04 pm »
Hmm my probes are only rated for 100 and 200MHz, and I seem to remember 500MHz probes and actives probes costing a fortune. I forgot about that part.
This solution works really well and does not cost a fortune:
« Last Edit: January 09, 2024, 09:40:07 pm by BillyO »
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
The following users thanked this post: james38, mathstudi
Offline WhittierChen
  • Country: cn
« Reply #501 on: January 23, 2024, 09:55:11 am »
Same process, same script.  :popcorn:
Could SDS6204 uses the same script?
Offline Martin72
  • Testfield Technician
« Reply #502 on: January 23, 2024, 11:35:03 am »
No.
(Kierkegaard)
Offline BitBangingBytes
« Reply #503 on: March 24, 2024, 01:23:01 am »
I'm running the latest software (5.0.1.5.2R3) and would like to get telnet access to try changing some of the logo files in the scope.
From what I have read I will need to access the hardware UART inside the scope to get terminal access, then enable telnetd. Is there any other way besides opening the scope? For those of you who have done it, do you just run an external cable to maintain access if needed?
Thanks for a great thread.
Offline tautech
« Reply #504 on: March 24, 2024, 01:56:01 am »
Please don't open the scope and please just continue reading.
« Reply #505 on: March 24, 2024, 03:17:34 am »
I tried creating the siglent_device_startup.sh script on a FAT formatted USB drive with the following:
#!/bin/bash
/usr/sbin/telnetd -l /bin/sh -p 2323 &
Inserted drive, rebooted a few times but nothing happens, no telnet on port 2323.
Some other magic potion I should be looking for?
Offline blurpy
  • Country: no
« Reply #506 on: March 24, 2024, 10:37:34 am »
#!/bin/bash
That feature has been disabled. There are no public ways of getting a shell with the newest firmware.
« Reply #507 on: March 24, 2024, 09:50:16 pm »
Thanks, I read a bit more and changed the little logo in the top right.
Offline Martin72
« Reply #508 on: March 24, 2024, 10:14:15 pm »
And what is that good for?
(Kierkegaard)
Offline KungFuJosh
  • TEAS is real.
« Reply #509 on: March 25, 2024, 01:19:45 pm »
It makes him happy. 🤷
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
The following users thanked this post: Martin72, BitBangingBytes
Offline james38
« Reply #510 on: March 26, 2024, 03:29:44 am »
He wrote recessim.
Latin for "backward" with the meaning of reverse engineering.
Still better than logir ;-)
The following users thanked this post: BitBangingBytes
Offline Mahagam
« Reply #511 on: April 02, 2024, 05:08:23 pm »
The new firmware has a new sw option (ARINC). Can someone tell me which keyword of this function is used in the script?
The following users thanked this post: maxspb69
Online maxspb69
  • Country: ru
« Reply #512 on: April 02, 2024, 06:17:11 pm »
Add the 'A429' option name to the Python code and generate a key for the option. I just did this.
It works fine!
« Last Edit: April 02, 2024, 06:39:09 pm by maxspb69 »
The following users thanked this post: H.O, Howardlong, james38, KungFuJosh, Anlefu
Offline apisa
« Reply #513 on: April 11, 2024, 09:00:34 am »
Hi all, just got a 2104 plus , I think the replit link that most people refer to for instructions to connect to scope, keygen, script, is down or expired.
apologies in advance if i missed it, if someone can give me the word to search in this or any post to get the most valid and up to date information to hack the scope i'd appreciate it.
also, it seems to be in contention whether bandwidth upgrade should go in increments, or all in one go.  I'm going to err on the side of incrementing, also the explanation seemed the more plausible. has the question of one time bw vs increment upgrade bw settled?
Offline tautech
« Reply #514 on: April 11, 2024, 09:04:26 am »
Welcome to the forum.
FYI, a 500 MHz BW upgrade is only possible from a preexisting 350 MHz model/license.
Offline apisa
« Reply #515 on: April 11, 2024, 09:14:48 am »
thanks tautech, I should have joined a long time ago.
I'm going to have a go with the cheap active probe method in the youtube above, I'll share my findings.  Found the 1103 PSU on ebay from a liquidator not far from me.  Still waiting for a more complete probe (with tip and gnd clip) to show up.
Offline szajsiwo
« Reply #516 on: April 11, 2024, 06:34:40 pm »
what about script compatibility with SDS2000X HD?
or maybe other solution for HD series?
Offline gwideman
« Reply #517 on: April 27, 2024, 10:01:53 am »
Just posting to thank those responsible for the script and other tips.
I will consolidate some notes that might bring other readers up-to-speed quickly without fussing around reading this entire thread:
-- SDS2104X Plus
-- Script: I used the one in message 409 of this thread.
-- Edit the script to change SCOPEID to the scope's id (from the Utility > System Info.)
---- Enter scope id in lowercase and numbers, omitting the dashes.
-- Run the script. [Note 1]  It prints a list of keys
-- Visit the Utilities > Software Options panel, select an option in the drop-down list, enter the key for that option from the script output.
---- Enter the key in lowercase and numbers.
---- You might think you'd need to plug in a keyboard, but no need, a decent one appears on the touchscreen.
Other concerns:
-- Originally the scope was at firmware V1.3.something. In that state it accepted a key for one of the options (and the option took effect).
-- The scope was then upgraded  to the now-latest released firmware, 1.5.2R3_EN
-- The scope retained the previously-set option.
-- The scope accepted additional keys for additional options.
[Note 1] The script is in Python language. You will need Python 3.something installed in order to run it -- free and easyish to install, but a burden if you have no other need for it.  Alternatively, search online for a site where you can run Python code by just pasting it into a text box etc.
Thanks again fellow EEVBlogsters.
The following users thanked this post: bairdbankovic, Anlefu
Offline Vertical Loop
« Reply #518 on: April 29, 2024, 01:52:29 am »
Updated script. Easier to read, no capital keys, added some comments. Worked for me still.
import hashlib
# Scope identification found in the system info tab
# to find this, touch the utility tab on the top left of the SDS screen.
# The dropdown will have a "Menu" option. This will open a dropdown on the right,
# select the (i) System Info from the dropdown.
# The "Scope ID:" hosts this variable. Remove the hyphens and keep the value lowercase.
SCOPEID = 'agy4mj75hf6jnd52'
# The model is a generic variable, not a specific model number, in this case the SDS2000X+,
Model   = 'SDS2000X+'
bwopt = ('100M', '200M', '350M', '500M', 'AWG', 'MSO', 'FLX', 'CFD', 'I2S', '1553', 'PWA', 'MANC', 'SENT')
hashkey = '5zao9lyua01pp7hjzm3orcq90mds63z6zi5kv7vmv3ih981vlwn06txnjdtas3u2wa8msx61i12ueh14t7kqwsfskg032nhyuy1d9vv2wm925rd18kih9xhkyilobbgy'
def gen(x):
   h = hashlib.md5(
      hashkey + (Model+'\n').ljust(32, '\x00') + opt.ljust(5, '\x00') +2*((SCOPEID + '\n').ljust(32, '\x00')) +
      '\x00'*16).encode('ascii')
   ).digest()
   key = ''
   for index, b in enumerate(h):
      if (b <= 0x2F or b > 0x39) and (b <= 0x60 or b > 0x7A):
         m = b % 0x24
         b = m + (0x57 if m > 9 else 0x30)
      if b == 0x30: b = 0x32
      if b == 0x31: b = 0x33
      if b == 0x6c: b = 0x6d
      if b == 0x6f: b = 0x70
      # every four characters print a space
      if index and index % 4 == 0:
        key += " "
      key += chr(b)
   return key
for opt in bwopt:
   print(f'{opt}: {gen(SCOPEID)}\n')
Offline rfindley
  • Embedded Systems Contractor
« Reply #519 on: April 29, 2024, 03:54:28 am »
I used to write software for option keys and firmware updates, so it's always interesting to see how other companies implement theirs.  I had read that Siglent changed things recently in newer firmware... or maybe just newer models, I'm not sure... so I was curious if this script could reproduce my legit-purchased logic analyzer key for the SDS3000X HD, and nope... it's different.
I was also curious about the .ads files (that's another interesting thread), and it looks like they're still using some of the same obfuscation techniques (reverse file, xor 0xff pattern), but it does look like it's not exactly the same as it used to be.  It's so easy to AES-encrypt these days, especially if the equipment is running Linux, so I wonder why they spend time doing weird obfuscation.  (Maybe it's an export control issue??).  Not that I'm complaining:  some people like Sudoku;  I like my challenges a little more difficult.  :D
The following users thanked this post: Peter_O
Offline KungFuJosh
  • TEAS is real.
« Reply #520 on: April 29, 2024, 02:53:34 pm »
It's not that recent of a change. They have two different licensing versions. The higher end stuff gets Lic 2.0, and the lower end and/or older stuff has Lic 1.0. The script mentioned above is strictly for Lic 1.0.
The following users thanked this post: rfindley
Offline blurpy
  • Country: no
« Reply #521 on: April 29, 2024, 04:24:42 pm »
Seems to work exactly the same to me. What change did you encounter with the obfuscation?
Offline IM3
« Reply #522 on: July 11, 2024, 08:53:35 pm »
Just an update on whether or not the Phyton script still works.
I was able to update my brand new SDS2104X plus with latest software version 1.6.2R1 without any problems. To be sure, I increased the bandwidth in steps of 100-200-350-500 MHz. Why wouldn't you take that extra time and have the risk of things not working properly at the 100-500 MHz step?
The changes in Vertical Loop's script in reply 518 provide a  clearer presentation. The capital letters have also been removed, which caused confusion for many.
I would like to upgrade my SDS5034X to be as easy, but I have not yet succeeded. Does anyone have any advice on this subject?
Offline tautech
« Reply #523 on: July 11, 2024, 08:57:09 pm »
Not possible with the public script.
Offline IM3
« Reply #524 on: July 11, 2024, 09:24:08 pm »
I was already afraid of that. But does 'not public' also mean that probably no one can help me with this?
I'm just trying.
