Author Topic: Siglent SDS2000X Plus Hack  (Read 197054 times)
0 Members and 12 Guests are viewing this topic.
Offline widlokm
Re: Siglent SDS2000X Plus Hack
« Reply #475 on: October 01, 2023, 10:15:53 am »
I'm playing around with the scope for a few days, and not everything works as before. Here is a quick summary:
Scope: SDS2104X plus, firmware: 1.5.2R3, hardware: 05-05.uboot: 5.4
- All license keys generated by python script are valid.
- It is not possible to get "telnetd" running with scpi "SHELLCMD" nor with "siglent_device_startup.sh" file on USB stick.
To run telnet I had to get serial console (soldering on mother-borad involved) and work from there. Having full access I've first tried to change root password with passwd and it worked (had to remount /usr/bin/siglent partition as rw before), however telnet login seems strange. I could login via network as "root" and my new password was accepted, but I did not get full root privileges. Skipping password checking with "telnetd -l /bin/sh" however did the trick.
I also tried some ways (found on other threads) to run telnetd permanently, but nothing worked. Finally I modified "/usr/bin/siglent/product_rcs_begin.sh" by adding "/usr/sbin/telnetd -l /bin/sh" line (of course also remount,rw /usr/bin/siglent is needed).
One more funny thing: there are some "options_***_times.txt" files in "/usr/bin/siglent/usr/usr", the seem to contain number or left uses of all options. If someone does not want to add permanent licenses it is very likely that modifying these files will do the trick.
 And finally a question: there is a "Developer options" submenu in "Utility -> Maintenance", that asks for a password. What is is menu? Is password known? I've tried my own root password set by passwd before, but no luck.
Best Regards,
Michael W.
Offline tv84
  • Country: pt
« Reply #476 on: October 01, 2023, 01:22:15 pm »
Try "siglentcd" and report back.
The following users thanked this post: JOFlaherty
Offline widlokm
« Reply #477 on: October 02, 2023, 07:41:36 am »
Success, Thank You!!
 It gives access to temperature monitoring, boot times counter, some calibration data manipulation and FSP debug (don't know what it does). Anyway it is nice to have full access to the scope.
Offline markus_jlrb
« Reply #478 on: October 02, 2023, 10:12:16 am »
And what is more important - the possibility to save factory CAL data.
tnx2tv84
Markus
Offline cragen
« Reply #479 on: October 09, 2023, 11:40:32 pm »
Does anyone know of a file I can modify to add a boot-time invocation of telnetd, that will survive a firmware update on an SDS2000X from V1.3.9R6 to V1.5.2R3?
I'd like to move to the new firmware, but rely on the telnet interface for various mods.  Like monitoring device temps to calibrate a PWM fan replacement, maintain the clock on localtime with ntpd, etc.
I'd prefer not to solder on a UART header...
Thanks,
Craig
Offline tautech
« Reply #480 on: October 10, 2023, 12:01:19 am »
V1.5.2R3 is mainly housekeeping of minor production changes whereas V1.5.2R1 has fixes and enhancements for numerous issues:
Measurement enhancement - Added setup/hold time: tsu@R, tsu@F, th@R, th@F
Optimized UI
Added SCPI commands for Measure Cursors and clearing measure items in Simple mode
Supported LXI (only with the Uboot-OS Version 5.4)
Supported time zone setting
Fixed several bugs
Webserver doesn’t show instrument UI if the scope reboot with a wireless mouse connected
Incorrect “Recall”icon in the File Manager
Scope freezes with AWG enabled and measure cursor on rise time
IP setting of AWG in Bode Plot not remembered after reboot
Network storage only works for SMB1.0
MEAS:SIMPle:ITEM\sOVSN,ON does not work as expected
Roll time incorrect at 1ks/div and 20kpts
Raw data not consistent in x and sinx/x interpolation modes
Math: Dx parameter of Derivation cannot be increased by universal control
Incorrect FFT sample rate
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS2000X%20Plus_V1.5.2R1_EN-2.zip
However its always best to install the latest version.
Offline cragen
« Reply #481 on: October 10, 2023, 12:27:47 am »
Yes, I'd read the release notes, and it looked like a worthwhile update.  I also noted from other posts, that I would loose the "siglent_device_startup.sh" trick via USB stick, and I would really like to maintain shell access to the scope.  Thus, wondering if there is a means to make a persistent file-system change prior to updating.
Craig
Offline MathWizard
« Reply #482 on: November 29, 2023, 09:21:34 pm »
I must say I'm loving this scope so far. I got the legit 200MHz upgrade when I bought the sds2104x+ a few months ago. So of all the things I would like to unlock, can I unlock the full 500MHz BW ? I've never used a scope over 200MHz, so I'd love to try it out.
I've read through some of these 2000x+threads before, and I've unlocked my PSU, AWG, and sds1104x-e=>1204. How hard is it to unlock these? What page are the key instructions on ?
Offline tautech
« Reply #483 on: November 29, 2023, 09:30:42 pm »
Same process, same script.  :popcorn:
Offline Martin72
  • Testfield Technician
« Reply #484 on: November 29, 2023, 09:37:57 pm »
Simply use the search function in this topic.
(Kierkegaard)
Offline MathWizard
« Reply #485 on: November 30, 2023, 12:27:11 am »
Hmm my probes are only rated for 100 and 200MHz, and I seem to remember 500MHz probes and actives probes costing a fortune. I forgot about that part.
Offline MarkusAJ
« Reply #486 on: November 30, 2023, 01:07:22 am »
Do you really have a needs to use probes with HF > 200Mhz? Most people use appropriate terminated coax cable.
I bought the SDS2104X+ in Dec 2022, it was one of my best purchases in last 20 years. Unlocking all futures using the Python script was done in ~20 minutes.
Online KungFuJosh
  • TEAS is real.
« Reply #487 on: November 30, 2023, 01:08:40 am »
Not as bad as you think. And there's a project with a 2GHz active probe being developed by a user here for under $200.
Also, this was done with a coax cable:
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
The following users thanked this post: mathstudi
Offline MathWizard
« Reply #488 on: November 30, 2023, 02:19:49 am »
Yeah I don't have any coax besides scrap cable TV coax, which I can't connect to anyways, and yeah it's probably 70ohm or something.
I have to get all that stuff and and NanoVNA this winter, but after some computer upgrades. There's a refurbished  SVA3021X on sale now, I'd love to get that, but I better learn on a NanoVNA, and I want those PC upgrades 1st.
Yeah I've seen that probe project, I would get 1. I was going to try making some real cheap/simple HF probe, I have to find Dave EEV video.
I have a few semi-broken 100-200MHz probes. I wonder what I can do with them.
Online KungFuJosh
  • TEAS is real.
« Reply #489 on: November 30, 2023, 02:35:50 am »
The source in my screenshot is a TinySA Ultra. It's pretty cute, but I got it because of TEAS, not because I have a use for it beyond that png. 🤣
Offline tautech
« Reply #490 on: November 30, 2023, 03:42:28 am »
There's a refurbished  SVA3021X on sale now, ...........
No such model.  ;)
Scope probes use a lossy coax which wouldn't be much use for the very low signal levels an analyzer can resolve.
Offline sy
« Reply #491 on: November 30, 2023, 10:16:07 am »
Hello, I have a SDS2104x+ (100MHz) upgraded to SDS2504X+ (500MHz) with the hack, however, I am unable to upgrade my software options. I have used the generated codes for my unique ScopeID, SerialNumber and Model, but the scope returns "The data is invalid!". Any suggestions? Thanks.
Edit: Additionally, I have tried using the SCPI command: LCISL optioncode hexkey, to no avail. Restarting the scope before entering a new code and downgrading to the original 100MHz to enter the keys.
Finally figured it out after trying things for ages until finally some software option keys worked.
Previously, I was using a script that required the option keys to be generated using serial number. I changed script to the one provided by @Elasia, and boom it worked.
Leaving this here for anyone else that comes across a similar situation. Note all software keys are lowercase input through UI. I put the keys in while on my original scopes bandwidth (not sure if that changed anything at all).  :-//
import hashlib
SCOPEID = '0000000000000000'
Model   = 'SDS2000X+'
bwopt = ('25M', '40M', '50M', '60M', '70M', '100M', '150M', '200M', '250M', '300M', '350M', '500M', '750M', '1000M', 'MAX', 'AWG', 'WIFI', 'MSO', 'FLX', 'CFD', 'I2S', '1553', 'PWA', 'MANC', 'SENT')
hashkey = '5zao9lyua01pp7hjzm3orcq90mds63z6zi5kv7vmv3ih981vlwn06txnjdtas3u2wa8msx61i12ueh14t7kqwsfskg032nhyuy1d9vv2wm925rd18kih9xhkyilobbgy'
def gen(x):
   h = hashlib.md5((
      hashkey +
      (Model+'\n').ljust(32, '\x00') +
      opt.ljust(5, '\x00') +
      2*((SCOPEID + '\n').ljust(32, '\x00')) +
      '\x00'*16).encode('ascii')
   ).digest()
   key = ''
   for b in h:
      if (b <= 0x2F or b > 0x39) and (b <= 0x60 or b > 0x7A):
         m = b % 0x24
         b = m + (0x57 if m > 9 else 0x30)
      if b == 0x30: b = 0x32
      if b == 0x31: b = 0x33
      if b == 0x6c: b = 0x6d
      if b == 0x6f: b = 0x70
      key += chr(b)
   return key.upper()
for opt in bwopt:
   print('{:5} {}'.format(opt, gen(SCOPEID)))
« Last Edit: November 30, 2023, 12:17:23 pm by sy »
Offline Iwnug
« Reply #492 on: January 07, 2024, 08:19:00 pm »
Hello, i have the same thing as hardware here.
Strange is: I have hacked it to a SDS2204X + via Touchpanel - but can't get back. So i tried it via the Webfrontend with SCPI,
there it worked. Also up to 500MHz SDS2504X + in SystemInfo.
A day later i tried to toggle again, with the stored keys that i got by the script, and again is it not working.
Maybe there is a counter or something else that prevents from switching down and up?
BTW: I have to thank many users here for all the informations that i've found here!
Offline cte
« Reply #493 on: January 07, 2024, 09:47:11 pm »
I might be wrong, but AFAIK "downgrading" (removing software options) via SCPI is not supported.
Offline tv84
  • Country: pt
« Reply #494 on: January 07, 2024, 10:18:04 pm »
But it should be possible to downgrade BW via MCBD command.
The following users thanked this post: cte
Offline axantas
« Reply #495 on: January 08, 2024, 10:35:48 am »
Up- and downgrade Bandwidth via MCBD command IS possible. I did it both ways.
>> it has to be done step by step 100/200/350/500. 100>350 might work directly - 100>500 does not work in one step.
« Last Edit: January 08, 2024, 10:38:32 am by axantas »
Offline tautech
« Reply #496 on: January 09, 2024, 02:09:09 am »
100% for my personal explorations…….
This is my first test after generating licenses to be sure you can.
Normally not required other than a double check the script generates the correct ones.
Offline BillyO
« Reply #497 on: January 09, 2024, 06:26:34 am »
100 > 350 > 500 seems to work, but 100 > 500 is accepted but does not produce a viable result.
Yes, this works.
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline Iwnug
« Reply #498 on: January 09, 2024, 08:53:12 pm »
Hello,
now that i am at home i tried it again:
It works, not sure what was wrong bevor.
Two things: i can change 100MHz to 500MHz in one step
and the second thing is
it works only via Network/Webbrowser, not via entering the codes via touchscreen.
iwnug
Offline BillyO
« Reply #499 on: January 09, 2024, 09:27:55 pm »
Yes you can, but your scope will not work properly at higher frequencies.
Would probably have been best to follow the advice of many that have been down that path and back before.  Now you'll have to go back to 100MHz and do it properly to get a full 500MHz +++.
I think you can skip the 200MHz, but you definitely cannot skip the 350MHz and still have things work out.
