0 Members and 11 Guests are viewing this topic.
I got two PDF certificates, sent via e-mail by Batterfly, with a big Siglent logo as well as the codes on them, both as barcode and as alphanumeric string.
Quote from: balnazzar on December 09, 2022, 09:33:14 pmI got two PDF certificates, sent via e-mail by Batterfly, with a big Siglent logo as well as the codes on them, both as barcode and as alphanumeric string.One for each option is standard.With install instructions ?The PDF license we get has alphanumeric and barcodes on it too but must be first redeemed at the Siglent license generation site where then you can chose to download another PDF with the actual option license code for the prescribed instrument (model and SN#) that we can Copy/Paste from and/or print and include in the box when we dispatch.Maybe you tried to install the redeem code ?We install purchased options so the instrument is right and ready for work !
Hello all, what is the status of the current BW hack for the 100MHZ 4 channel model?
Right I see and that's without the hack?What about after adding the 350MHz BW to the 100MHz model specifically.
Should the code returned from the "MCBD?" command be the same as that generated by the script for option '100M'?
And if they are different? How else to check it?
Hello and have a nice day.I bought the SDS2102X-Plus. thanks.Greetings from me, Andy
Quote from: Andy_70 on February 04, 2023, 04:04:27 pmHello and have a nice day.I bought the SDS2102X-Plus. thanks.Greetings from me, AndyNice!I thought they were discontinued. Did you buy it used?
According to the options, I only have the 350MHz option. Does this mean that the SDS2102X-Plus cannot be expanded to 200 and 500MHz?
Hi,I feel misunderstood. After I made the only bandwidth option (350), no other BW option is now available. The device is now recognized as SDS 2104X Plus, that can't be.
How can I increase the bandwidth to 500 if there is no option for it?
Where do I enter this? I have no idea.
